Advice on Mini Front F Sport Tag
I recently purchased a 2014 Lexus GS 350 F Sport. The vehicle was delivered in California. I removed the Front License frame, as Georgia does not require a Front license plate. Any advice on where to find a 'F Sport' mini plate to put on the front? This will be for the area between the grills.
Thanks.
Thanks.
Ebay is your friend for this kind of stuff:
http://www.ebay.com/itm/Lexus-F-Spor...129?rmvSB=true
If this is not what you are referring to then I'm sure you may find it on there or Amazon if you search hard enough.
Thanks for the responses. Any recommendations on where to purchase the custom European front license tag?
This is where I had bought mine at. It looked great I took it off because Im going to get the holes filled in.
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1500/img_2670_3f51150108fecd4616b84e79d17af7d0073b5ce3_e5ed618a88240cf7d89b0593504e9dde9065c2d6.jpg)
corpnupe85 (05-12-17)
Kcatunna82 - Thank you! Nice looking vehicle!!
kcstunna82 (05-14-17)
Hello All,
Thanks for the responses. I am not liking what I am reading about the brakes on 350 F Sport models. I will most likely trade for a 2016 450h. This thread can be closed.
Thanks,
Thanks,
corpnupe85 (05-14-17)
There are several threads about issues with the F Sports brakes needing to be replaced every 20,000 miles.
It depends on how you drive it.
Rear brakes are same for all models. front's are heavy duty compared to standard. You can install standard style pads that will last much longer.
corpnupe85 (05-15-17)
Patrick047
03-24-15 09:05 AM
xRYD3Rx
03-03-15 11:53 AM
