Excessive wind noise from Sunroof repaired by dealer for free.
#76
I had my moonroof repaired after an extended argument - I brought the car in with the same complaint 2 times before and once after the warranty expired, and they tried to tell me that Lexus was not responsible. They did the TSB fix, but I still hear occasional knocking, and the wind noise is better, but still there.
Before, one corner of the moonroof could be moved with 1 finger; now it is solid.
Since it's been about 6 months since the fix, and I am well out of warranty, I am considering changing the gasket again myself. ANy thoughts baout how much better (or worse, of course) I might make it?
#77
Thanks. Are there any special adjustment procedures?
Should the entire moonroof be flush with the roofline, above the roofline, or below?
After Lexus did mine I can see that it is not uniformly flush; perhaps an adjustment first....
#78
You'll see the pics from the excellent write up from fellow member mryeh17...
#80
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
#81
Originally Posted by Spideyman1
I went to take out the (4) T25 screws, had a 3/8" ratchet drive with a bit, all were very had to break loose, stripped one, thought, now what
?!?!?! I was able to tilt the sunroof up and get a vise grip on the head of the screw and managed to get it free. Replaced the gasket, reassembled. Didn't drive it yet though.
#82
I had seen the post on that, but I didn't' think I could get the gasket on with my bog meaty paws without removing the panel. Nice work!
#83
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
#85
Those T25 screws are a pain in the ***! I ended up stripping out one of them. So I went to Lowes got some M5 x 10mm screws and replaced the front two with phillips head screws. The good news is that the seal is fixed and the wind noise is gone! WOO.
Took me about 2 hours because of the stripped screw. The seal took about 10mins to take off and put back on.
#86
Hi guys. I wanted to try this for myself and I went about searching the internet for the part. The part number mentioned in this thread, 63251-30100, seems to be specific to the US since when searching for it only sellers from the US can be found. Does anyone have any idea how I can find the comparable part number for Europe?
#87
There is a TSB out on it. My friend who is a lexus tech told me to get it repaired as soon as i got the car because it will only get worse and is expensive to repair out of warranty. So i made up a bull**** excuse they performed the following TSB.
http://www.revbase.com/BBBMOTOR/TSb/...dPdf?id=175340
#89
If you read the second part of the TSB from that link, you'll see that Toyota has clarified which cars they'll fix - the TSB indicates that it will be fixed only if you are currently under the factory 4yr/50k miles. It certainly doesn't hurt to ask your Lexus dealer if they'll fix it if you have an extended/platinum warranty.
