Bumper Repair / Touch up Suggestions
I banged into one of those yelllow cement poles. It chipped the paint off the bottom of the bumper and vertical line on the right which feels like a scratch. See attached image Should I just get touch up paint/pen ? Do I have to worry about clearcoat?
2016 GS-350 F-Sport Nebula Gray
That damage seems a little too severe for just touch up. It'll probably have a noticeable blemish after touch up. I would probably go to a few paint shops and get some estimates; re-painting the bumper shouldn't be too expensive.
Touch up isn't going to work there, you will have to have the bumper replaced/repaired and repainted.
Sounds about right...
I would first wash it off thoroughly and try polishing the scratches with a little compound/polish to see exactly what is damaged and what can be fixed. Since it is low in your bumper you probably could touch it up and do some wetsanding and polishing and have it look pretty good, it would likely not be noticeable unless you know it is there and look for it. If you don't want to go that route or pay all that money to fix just a small portion of your bumper you could try it yourself and have a paint shop mix a urethane basecoat and spray it and then clear with spray max 2K clear. It would cost about $45 in paint and clear and you would need a respirator for spraying the 2K clear. You can get impressive results if you practice some and read up on it.
I've worked on damage on cars like that before, no way to make it look good on the cheap. The paint is sheared away in a large area, can't be touched up. Sure you could try and spray it but it's a pearl paint and it's going to look like hell.
It's a $55,000 car, I don't think that money is unreasonable to repair this damage.
Don't go cheap, usually cheaper guys are bad in matching the color. I think some filling might be required also since the shape of the bumper has changed from the place of impact.
If it were my car I would want the bumper cover replaced
Both Toyota and Lexus has referred me to http://www.automotivetouchup.com/index.htm . They have exact instructions on how to repair the damage. It helps if you have a buffer.
I used it on my RX with similar damage and my brother's Camry and it turned out really good. Both cars are also pearl.
My dad sprayed his clear coat failing bumper using a mixed aerosol urethane and 2K Spraymax and other parts with a metallic flake paint he got mixed and it turned out very well, almost a exact match which I was shocked it matched so well, did not think a general paint shop could mix a Acura metal flake paint that well. He will have to use some filler on the damage but with a little research and practice you can get some very good results with a urethane spray and 2K spray which is the same type of finish from the factory, him having a buffer will help too. Paying $1100 to $800 may not be unreasonable to you but it may be to the OP for relatively small paint damage which may likely happen a few times throughout ownership. What is the worst that could happen, if he screws up or does not like the finish he is out $50 and it can then easily just be painted over by a professional.
Sorry, i just don't get it. Its a year old $55,000+ car, I don't understand spray painting it at home to save $400-800. If a car has so little value to you, I question why one would spend that much money on one in the first place. If it were 10 years old that would be one thing, but its not, he's making a big payment presumably to drive a 1 year old Lexus. I don't understand why somebody would want to look at a poor quality repair on something thats costing them that much. Just in depreciation the thing is costing $1,000 a month right now. The sort of damage that will happen a few times throughout ownership? You guys must run into things more than I do, I backed into a pole and damaged my car one time in the 20+ years I've been driving. On top of that I've had cars run into at no fault of my own 3 times that have required damage repaired that I did not have to pay for, none of those cars do I currently still own.
Nebula Grey Pearl is a pearl coat color. So it has a base coat, a pearl coat, and a clear coat. This is not a typical metallic paint color and is difficult for a professional to match properly, let alone a person at home with a sprayer.
With a pearl paint like this, it's not just about having the paint itself match, the way the metallic and pearl flakes lay on the surface has a huge impact. I have this color and I have attempted to touch it up in places, and I've had it professionally touched up, I know how this is going to turn out.
Sorry I just don't agree with spending this much money for a nice car and cheaping out with a DIY paint repair, I think that's silly. I spend a lot of money on my cars and I care for them accordingly, they're not "covered in rock chips and dings" like you describe your cars. All we do here is offer our opinions to people right? I would never attempt such a repair to one of my cars because I would never be happy with the result. This isn't a rock chip, this is a sizable damaged area to the bumper and in any event when my car was new I spent $1,400 on a full clearbra to avoid the issue of rock chips.
I'd rather just do nothing than hit it with spray paint myself and have it look like hell. I spot these janky repairs from a mile away and they always make me shake my head when they're on a nice car.
As for the $10k for a volume ****, of course not, and that GS is not a year old. I wouldn't however rip the **** out and put some non-matching **** in there which is a suitably analogy to what you're recommending here. Plenty of sources for a replacement radio unit, salvage sources, you can have a radio shop try and repair it, etc.
$10k for a radio **** and $400-$800 for a proper bumper respray and repair are worlds different.
Imagine if he spends $800-1100 dollars to get it professionally repainted and something else happens a few months to a few years down the line in the same general area, he will be out even more money and it was a waste to spend all the money the first time. If he is happy with a DIY fix then he can just wait until maybe he is selling it to make it look perfect if he is worried about getting as much as possible and by then he may have found someone good that will do it for much less or maybe he won't mind a buyer wanting to knock a few hundred off if they see and don't like the paint repair.
Again, he can always try a DIY method and if he is not happy and can't live with it just have it professionally repainted, he will only be out about 40 or 50 bucks for the DIY.
