Ventilated seats?
hey guys,
with this 100+ degree weather in california, is been miserable.
for the past week, i drove my car to work and when i get off of work.. i turn the ac on and the seats.
but lately, the seats been warm even though is on cool.
has anyone else experienced it before?
thanks
thanks
Nope.
Do you get a chance to start your car prior to getting in? I usually give Enform a tap to get mine going a few minutes ahead of departure and it takes some of the 100*+ down.
I don't know if you're having an issue per se, maybe have it looked at.
hey guys,
thanks
thanks
They're ventilated seats, not cooled seats unfortunately. The ES has cooled seats. What you're feeling is just a fan circulating air so it won't feel cold ever, unless you're not feeling anything at all coming out. Try turning the passenger ventilated seat on when no one is seated, you should be able to hear the motor running.
Perhaps the LS has true "cooled seats"? I'm not sure.
If the ES was different and had true "cooled seats," I would find that absolutely stupid on Lexus' behalf since they would putting a better product in a lower tiered model.
~ Im2bz2p345
TrevorTran (06-23-17)
Reading through this thread (https://www.clublexus.com/forums/es-...ted-seats.html), I believe that the ES also has ventilated seats.. not true "air conditioned seats" (i.e. the air from the cold A/C is not routed into your seats).
~ Im2bz2p345![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
~ Im2bz2p345
On a hot day it's best to let the A/C cool down the cabin interior for a few minutes before turning on the ventilated seats because the ventilated seat fans are drawing cabin temperature air from near the bottom of the seats and pressurizing this air up through the seat bottoms and seat backs.
You should feel the slight airflow from the seat back and seat bottom. To confirm that the ventilated seats are working - lean forward toward the dash and you will hear a rush-of-air noise from the fans.
I have a lot of experience living in Dallas where it oftentimes gets over 100°.
