Does it feel like the car is going to stall? It maybe a bad batch of fuel or water somehow got into it. Could be motor mounts as well like you said.
No car feels fine, doesn't feel like it's outta breath or anything. I'll probably drop by the shop soon to get it checked out. 5 year old ride may need to replace the mounts. I hope it's just the mounts and nothing more serious.
I did a while ago. How do I fix this? Clean the plugs?
I don't know if cleaning the plugs will help. Maybe you need to replace them. I would talk to a trusted mechanic before doing anything because you don't know the cause for sure.
Does the vibration go away if you put it in Reverse? If yes, then it might just be a bad mount. If its throughout the gears, then you may need to replace your spark plugs. If its a bad mount, it should be covered under your power train warranty.
