Trunk won't open!
Old 09-18-17, 08:48 AM
  #31
Davenlei
Davenlei's Avatar
Today I am now having the dreaded "trunk wont open issue" too.
The button (inside and at the trunk) and the key fob does not open the trunk. There is no click of the actuator for either. When I used the key to open the trunk (key hole under the license plate lid), it opened and I was able to access the trunk.
There is barely anything in the trunk (jumper cables in its case and sub visor) so they cant claim something got caught in the mechanism. I don't have any license plate covers or anything like that either.
To me it sounds like a blown fuse or dead solenoid for the trunk.
Made an appointment and will be taking in into the dealer today since I am still under warranty. In addition, I have another leaking front strut. The other side this time.
Old 09-18-17, 11:44 AM
  #32
Davenlei
Davenlei's Avatar
Well, took it to the dealer. My son had accidentally pushed the valet button in the glove box. Once deactivated, trunk worked fine! :almface::
JellyBean (09-18-17)
Old 06-05-20, 05:21 PM
  #33
GS350Boi
GS350Boi's Avatar
I realize this thread is many years old. I just wanted to share just in case someone else has this problem and finds this thread.
6/5/2020
My GS trunk would not open. Interior trunk release did nothing. No sound either. Trunk key fob button did nothing. No sounds made either. The physical emergency key DID OPEN the trunk.
The Problem?
Just like the poster above me, the valet trunk button in my glove box was pushed. Once I release the glove box button, everything worked perfectly again.
Cheers!
The following 2 users liked this post by GS350Boi:
Im2bz2p345 (06-05-20), websurfer (06-06-20)
Old 06-05-20, 07:05 PM
  #34
peasodos
peasodos's Avatar
Received 2,229 Likes on 1,450 Posts
Originally Posted by levinsoy
My local dealer said they have tried to use the key as I did but it doesn't move and they unplugged the battery cable and that didn't fix problem so they are basing the diagnostic fee on that something is stuck and I am responsible. The $550 includes 3 hours of labor for tech to remove back seat and crawl in there to open safety latch or to see why trunk will not open. I'm beginning to question dealership. Thoughts?
3 hours to remove the back seat is BS.
there are two clips and like 6 bolts to remove the back seats. I have taken them out myself takes 10-15 minutes at the most.
then they can pull the green emergency trunk release. It could be an issue with the latch mechanism. The emergency trunk release pull on the latch part directly, instead of indirectly.
honestly if you open the middle trump pass through you can put a rod with a hook to grab and pull the emergency release without removing the seats. I would take part of a coat hanger duck taped to a broomstick or something like that to grab the release.
Schimmy
05-31-24 12:03 PM
sprtn131
08-13-15 05:48 PM
jarm
11-12-12 06:48 AM
bobnxena
10-08-10 05:02 PM
beewhyon
02-15-09 02:58 PM
Quick Reply: Trunk won't open!
