Sunroof clunk/rattle
Old 09-21-17, 02:02 PM
Evilken
Evilken's Avatar
Just got back from the dealer. We went on a "test ride" where a mechanic sits with you to observe the issue. Initially it wasn't making any rattling noise like it usually does, then after a 25 min drive, 2 blocks away from the dealer, the moonroof started to rattle. They are going to research it and get it fixed. Car should be ready early next week, will keep you guys updated.
Boomin (09-21-17)
Old 09-29-17, 02:15 PM
Evilken
Evilken's Avatar
Got the car back today and so far so good!
Here are the things that they replaced
63203-30180 - Housing Sub-Assembly
63205-30070 - Cable Sub-Assembly
63217-30100 - Garnish, Sliding
63251-30100 - Weatherstrip, SLI
Old 10-07-17, 12:36 PM
sonyfan
sonyfan's Avatar
I replaced the weatherstrip myself, now just need to see if clunking will go away
Old 10-08-17, 12:48 AM
GS350L
GS350L's Avatar
Default Clunk Cause in my 2014
I have the same issue described in this thread. I found that the best way to recreate MY sound without driving is to sit in the car and put a hand on each side of the sunroof glass, then slightly shift it left to right. It makes the exact click/clunk sound I get when driving. When sunroof is open at all, the noise can't be reproduced manually or while driving.
Dealer trip is coming up.
Old 10-23-17, 11:26 AM
GS350L
GS350L's Avatar
Following up on my dealer visit, they replaced the main seal and it fixed my issue. I can't reproduce the sound any longer and no more sunroof noise over bumps anymore.
It's important to note that I only showed the service adviser how I was able to reproduce the noise while it was sitting still - we never road tested. There was never excess wind noise as the tech stated in the notes and I couldn't see that the seal was "deformed" from the outside of the car. If you can reproduce your noise doing what I outlined above, I would highly recommend looking into getting this seal replaced. https://www.lexuspartsnow.com/parts/...251-30100.html
Old 10-24-17, 02:29 PM
Davenlei
Davenlei's Avatar
So I had the wind noise and rattle also. They replaced the main seal around the glass and that fixed the issue for about a year. After a year, the roof started to tick when opening. They adjusted and lubricated the moon roof and that took care of that noise. After a week, the tick came back along with a thunk and slam when opening the moon roof. I took it back in and they said the tray/track was bent. They replaced the assembly, tray, cable, main seal and other parts. The job was a major repair and required the windshield and headliner to be removed. Everything is back together good and no squeaks, rattles, wind, thunk or slams... It actually opens and closes much smoother and easier than it ever has.
Luckily the repair was under CPO warranty because it was over $2,600.
Old 11-01-17, 02:10 PM
GS350MIKE
GS350MIKE's Avatar
Originally Posted by Mike552
I had the sunroof clunking noise repaired by my dealer. Mine is a 2014 CPO and i am not sure if the dealer fixed it under warranty or if it was good will. I know they replaced the cables.
Just picked up a pre-owned 2014 F Sport from Keyes Lexus last week, and sure enough I have wind noise and rattle on bumps - both from the moon roof. The car is at the dealer for a Due Bill from the sale of the car, and they're trying to hear the rattle and wind noise so they can fix both under the factory warranty. I'll let you know once I get it fixed....they might just do the seal and they might have to replace the whole assembly according to the service manager.
The only annoying part is that they can't seem to hear the rattle and noise that I was hearing. This means I have to go in, take a drive with the shop foreman, and make sure he hears it. This kind of surprises me from the standpoint that they obviously know about this TSB for the 2013s, they know the seals are not great, so I would think it would be easy for them to listen for signs of the problem, and then make the claim to Lexus and start on the repair
Old 11-01-17, 05:02 PM
OneFunGS
OneFunGS's Avatar
Will the still replace for free/reduced cost under the TSB for 2013/2014?
Old 11-01-17, 05:54 PM
yardie876
yardie876's Avatar
TSBs are honored while still within warranty. If you’re no longer under warranty, a dealer may goodwill the service or offer a discount, if they want.
Old 11-02-17, 04:50 AM
OneFunGS
OneFunGS's Avatar
Thanks. I have wind noise as well and my nearest lexus dealer is 3 hours from me lol. I am trying some seal rejuvenation soon to see if that will help
Old 11-06-17, 06:03 AM
GS350MIKE
GS350MIKE's Avatar
the shop Forman rode with me, heard the clicks and wind, and they replaced the seal. Problem solved. Under warranty.
I will pay attention for the next 8,000 miles leading up to 50,000, and if it starts again I will push hard for the assembly replacement and/or the upgraded seal.
MrJamison
GX - 2nd Gen (2010-2023)
21
11-05-22 02:54 PM
Incognito8
05-13-14 08:36 AM
aira
03-08-12 10:26 AM
tazdevl
01-06-07 11:44 AM
BigMoNYC
07-30-05 10:48 AM
Quick Reply: Sunroof clunk/rattle
