Advice needed - gear hunting in a 6-speed GS350
Hi all
I've been test-driving a 2013 GS350 with a six-speed auto box. It feels like the car is hunting for gears with the kick-down in gear fierce but normal cruising fairly lazy on throttle response. My understanding is that this is a problem with the 8-speed box in later years.
I've toggled the settings between eco, normal and sport but haven't noticed a big difference between normal and sport.
Has anybody experienced a problem like this? Is this a known problem with an easy fix?
I don’t recall any transmissions issues with the 4GS that have required replacement or service since I’ve been on these forums for ~5 years. The transmission shift logic learns and adjusts shift behavior depending on the driver. If the previous owner drove it like a Buick then it may be the cause of the slushbox feel you experienced. Just a thought.
Hi all
Hi all
If you like the throttle response of Sport mode but without unexpected shifting - drop it to Manual(best part is you also get rev-matched downshifts here - warning: it's addictive).
Also, for those GS 350 owners that may not already know:
At WOT (wide-open-throttle) the GS 350 engine performs at Sport/Sport+ mode throttle characteristics regardless of which drive Mode is selected, including even ECO Mode.
Also, the GS 350 transmission will automatically upshift at redline regardless whether the transmission shift selector is in Drive or in Manual. In other words, if you were at [say] a drag strip and selected manual shift 'M1' - you could leave it in 'M1' and never upshift and it will automatically upshift at redline.
I don €™t recall any transmissions issues with the 4GS that have required replacement or service since I €™ve been on these forums for ~5 years. The transmission shift logic learns and adjusts shift behavior depending on the driver. If the previous owner drove it like a Buick then it may be the cause of the slushbox feel you experienced. Just a thought.
As i've been driving in city traffic, the car has cooled off so to speak. It feels just fine during full throttle but city speed limits around here are 25mph with speed cams all over so getting to 25 happens quick enough (probably true in almost any car)...its only on the highway where you can really test the GS.
OP: I'd say disconnect the battery for a bit, reconnect and retry (not sure if the dealership where you are test driving will do this though). If possible, test drive another 6-speed GS and see how it compares.
I didn't really believe that this happened until I drove through the mountains a few times and now my car literally holds gears when it makes no sense other than I previously down-shifted with the paddles as I approached the curves, and now I notice as I drive aggressively in "D" Sport + the car down-shifts quickly and holds the gear for me!
I believe the above chart applies to the GS 200T as well. I have a 2016 GS 200T (non F-Sport). Between the ECO and Sport modes, I cannot perceive any difference in steering response/feedback. I wish I could. I do perceive a difference in throttle and shifting characteristics. Perhaps other non-F-Sport GS owners can chime in regarding whether they perceive any difference in steering response/feedback between the ECO and Sport modes.
In my old BMW you could reset the transmission shifting points and have it relearn your driving by putting it in the 1-2 key position and holding the throttle down for 25 seconds. When you start it it would adjust to how you drive. I don't know if there is any method for these cars for doing the same thing without disconnecting the battery. But disconnecting the battery should definitely relearn. Maybe I'll search on the IS forum to see if theres a way since its the same setup more or less. It makes me wonder if since I installed my apexi accell how it effects the shifting, and how it would react if I disconnected the battery and relearned it in the mode I'm usually in (red).
