Moonroof rattling / clunking? Here’s the fix!
Old 03-24-20, 04:37 AM
  #136
peasodos
peasodos's Avatar
Received 2,229 Likes on 1,450 Posts
Originally Posted by Nasnasg
Hi to all from France.
thanks to you i've oundf the the answer of my clunking problem 6 months ago.
Lexus dealer here in France changed me the sunroof seal.
And it worked greatttt till.....
But guess what. After only 6 months it's back.
I bought a new seal and i have to say there is a huge difference between them in only 6 months.
The new one is like fluffy and the old one is all smooth.
Plus you can see a gap between seal and body frame like if the seal was retracted on it self.
i remember when we changed it 6 months ago i had the same reaction with the new seal and old seal.
The question is, how the seal can degrade that way in only 6 month?
I replaced mine over 2 years ago and no issues, not sure whats happening with your seal.
Nasnasg (03-24-20)
Old 03-24-20, 07:18 AM
  #137
Nasnasg
Nasnasg's Avatar
I used a ceramic product after the the cleaning of my Gs.
You apply it with a foam canon.
This is Alchemy7 Ceram'X
May be it cause the problem by making the seal dry.
By the way, i apllied Shin etsu on the deaf seal and it worked for 2 week then the clunking returned.
Thx
Old 03-24-20, 08:12 AM
  #138
JDR76
JDR76's Avatar
Received 1,616 Likes on 1,030 Posts
Where in France? I lived about an hour from Lyon for a time.
Old 03-24-20, 09:24 AM
  #139
Nasnasg
Nasnasg's Avatar
Lille in the North
JDR76 (03-24-20)
Old 03-28-20, 10:07 AM
  #140
UDel
UDel's Avatar
Is it really critical to get the drain hole centered in the back, the drain hole is not totally centered so far but the green dots are pretty even on each rear edge.
Old 03-28-20, 10:10 AM
  #141
Nasnasg
Nasnasg's Avatar
Same for me too. I think its the way it must fit.
UDel (03-28-20)
Old 07-31-20, 09:23 PM
  #142
DiscoJango
DiscoJango's Avatar
Bump for this thread. So i have purchased the new seal, taken my sunroof off, removed the old seal however im having difficulty installing the new seal. I cant get it on tight? No matter what i do, it just sits very loose. Is there some trick to getting it on tight?
Edit, got it!
Old 07-31-20, 09:26 PM
  #143
mrplesh
mrplesh's Avatar
you might find it helps to put it on while rotating it. What I mean is place the seal tilted on an angle and push it into the sunroof at an angle and then rotate it straight while pressing it in.
The following 2 users liked this post by mrplesh:
DiscoJango (07-31-20), rjm (08-01-20)
Old 07-31-20, 10:20 PM
  #144
DiscoJango
DiscoJango's Avatar
Thats exactly what i was missing. I initially thought it literally just goes on, when in fact it requires a bit of a squeeze n turn maneuver to get it nice and tight!
rjm (08-01-20)
Old 07-31-20, 10:22 PM
  #145
mrplesh
mrplesh's Avatar
Were you able to get it installed?
Old 08-01-20, 04:12 AM
  #146
DiscoJango
DiscoJango's Avatar
Yes, but after quite a bit of stuffing around. Initially i tried the method where you do not remove the sunroof, and instead tilt/slide it and feed the rubber seal. My sunroof kept closing and then opening when i tried this, it must be something that detects if something is blocking the sunroof mechanism? I then tried to remove the sunroof with a screw driver however the bolts were on too tight, luckily i had a drill small enough to fit in the space and undo all 4 bolts, which came off easily. I was afraid i would thread them like someone else did. I sprayed a good amount of silicon lubricant on the seal and then squeezed/rubbed it onto the sunroof. All up took me about an hour, however if i had to do it a 2nd time knowing the process, i could smash it out in around 15-20 minutes. Re-installing the sunroof and getting it aligned was a piece of cake as well!
Took the car for a good 15 minute drive over some bumpy roads that previously made it rattle like crazy and just...silence
rjm (08-01-20)
Old 08-16-20, 06:40 PM
  #147
mthorne76
7th Gear
mthorne76's Avatar
I have found the source of the noise from my sunroof. The plastic mounting from the sunroof that slides within the aluminum track is the source of my clunking / rattling sound (shown in attached pictures). With the sunroof open I began banging on the glass to find the source of the sound. I was able to see the up and down movement of the plastic mounting within the aluminum track. When I held the glass tightly against the aluminum track and I banged on the glass, there was no sound. It makes sense that the sound seems to come from all around you / even the rear of the car as the sunroof is in the area between the inside and outside of the car - allowing the sound to travel around. I'm hoping that my replacement of the seal will cause the prevention of the vibrations between the body and the glass and then down to the track that the sunroof slides in.
Old 08-17-20, 03:59 AM
  #148
DiscoJango
DiscoJango's Avatar
Only one way to find out, and its a relatively cheap and easy fix that you can easily do yourself. My local lexus dealership was closed on the weekend so i just ordered the part from toyota.
Old 03-10-21, 02:47 AM
  #149
Ktrav103
Ktrav103's Avatar
Originally Posted by xpandabl3
Yeah mine clunks regardless the sunroof being open or closed as well...I tried to move the sunroof in all direction either when its closed or open, it's rock solid.
Sorry for the trouble, but can I still trouble you to share what your dealership do to fix the noise? judging we all have 18' F-sport. Thanks.
I have a 19 with the same issue!!! What did you find with yours??
Old 03-21-21, 06:54 PM
  #150
Andrewka
Andrewka's Avatar
Originally Posted by danen1973
When the sunroof is open or tilted up I don't hear any rattling.
Thanks, I'll take it to the dealership and ask them to replace the seal.
I have a 2013 gs350 f sport, replacing this weather strip resolved the rattling. I'm just not sure how. All 4 screws that held the sunroof in Place were tight, I checked around the sunroof for any loose parts and didn't find any.
It was easier for me to take the sunroof off completely because putting the weather strip on with the sunroof still on the car did not give me a lot of room to work with.
Thanks for posting this resolution , that rattling was super annoying.
Quick Reply: Moonroof rattling / clunking? Here’s the fix!
