Moonroof rattling / clunking? Here’s the fix!
jgscott (06-30-23)
bclexus (06-30-23)
#199
Tried this today and the new seal is too loose. I removed the front tied bolts to make it easier. I can place it around all 4 corners and there is still slack around the front and back. When I try to shut the sunroof the seal slips out of place.
Tried to put the old one back on, it’s got a bit of slack too now.
using part # 63251-30100
#202
You have to really firmly push the seal until it clicks / clamps down to the inner grooved on the sunroof lip.
#203
That is the correct part number unless you purchased a generic (as in not made by Toyota) from places like Amazon The slack is due to the seal not being firmly seated onto the sunroof edges.
#204
Finally got the time to attempt this DIY - used the method without removing the glass. Took a bit of trial and error, but finished in ~ 40 minutes. Sunroof clunk appears to be fixed! Thank you to everyone who posted detailed pictures and instructions.
#205
This may come off as ignorant but will this same fix work on a 2014 Lexus IS 350 F-Sport? I just purchased one and it's having the rattle issue. Just want to make sure this applies to the 2014 IS350 before I take everything apart and start working on it (going to be replacing the sunroof motor as well).
#206
KC98LS
12
01-29-23 10:40 AM
KellyC
09-15-12 10:34 AM
