Does the speed sensitive volume control work in your 4GS?
All 4GS (with or without navigation) has the standard option for speed sensitive volume control which can be turned on/off by turning the "Automatic Sound Levelizer" (under DSP under Sound Settings) on/off. Turning it on or off does not seem to make any perceptible difference in my 2016 GS. I have been trying to find out the experience of others and found this short thread where the OP was complaining that when turned on, the volume increases too much for his taste: https://www.clublexus.com/forums/sc4...ve-volume.html . For me, the volume does not seem to change at all. Please share your experience.
My 2009 Maxima had multiple levels (possibly 5) of speed sensitive volume control. My 2016 GS only has on/off. Is it possible to enhance the change in volume with speed through the dealership or any other way?
So you and I have had a similar experience. I had an Altima with the speed sensitive volume that changed quite dramatically.
Since then I have owned 3 non-nissan luxury cars with this feature and struggle to tell if the volume changes at all! My theory is that Nissan's system changes much more than the rest and thus ruins the experience in other cars with this feature.
jonathancl (11-16-17)
Yea! I have struggled for years to cope lol
This is interesting. I owned a Genesis Sedan and didn't notice the changing volume in that either. I believe my Nissan theory to still stand!
I toggled this on the way to work this am.
Didn’t really notice a difference. Volume at low mid and high. Rolling at 65+.
Interestingly enough though I didn’t really feel like it was less audible with the windows open, assuming it raised the volume?
Tried a few different variations and with the windows closed I didn’t think it adjusted anything. Mind you the GS *imho* in an extremely quiet car. Maybe it just doesn’t need to because it’s so isolated from the outdoor noise? Windows, sunroof open will get further testing.
2013 ML, can't tell that it does anything. I adjust the volume up and down manually all the time.
My 2001 GS430 ML nonav was amazing! It was so perfect, I NEVER had to touch the volume no matter what I was doing.
I couldn't even tell that it had made an adjustment: the music was just...right.
I do love my 2013...the improvements in interior and technology and awd are all excellent...but there were some things about that 2gen machine that set the bar very high.
I know that M-B's audio volume level adjustment can be based on one of either the vehicle's speed or the ambient noise in the cabin, which is dependent on the particular sound system option the vehicle is equipped with. I'm not sure about Lexus...
Originally Posted by bclexus
Is the audio volume adjustment made based on 'speed' or is it based on the 'ambient noise' level inside the cabin?
I thought the same question. As stated, it €™s so quiet regardless of speed that it €™s no surprise that it doesn €™t really adjust with speed. Has to be other factors...open windows and sunroof. Not sure how it determines how much to compensate but that €™s the only thing that makes sense to me.
I've never tried it, but you should be able to run a simple test to determine if the vehicle's volume changes based on ambient cabin noise, or a combination of both speed and cabin noise. All you need is a handheld noise-maker, which your iPhone can be used for - just play a song or a video with some music - turn up the volume on the iPhone and hold it near the microphone up on the roof console. If the car's automatic volume adjustment is based on both speed and ambient cabin noise the speed threshold is probably set at around 35 mph before any change in volume adjustment is automatically made based on ambient cabin noise.
