Winter Weight - RWD
Old 11-16-17, 08:22 PM
pseconds
pseconds's Avatar
Default Winter Weight - RWD
Okay, so I'm in a northern place that has already had the first snow. My rear wheel drive GS could barely get going from a stop sign on flat ground. Getting RWD in a snow climate was not a smart idea I guess, but I'm kinda committed at this point.
I was going to add some weight in back to see if that helps. Do I put the weight right over the rear axle, or further back? And how much weight? I've got good, fairly new all-season tires, and not excited about spending $1000 on winter tires.
What do others do?
Old 11-16-17, 09:14 PM
PsykotiK
PsykotiK's Avatar
you need winter tires if you want to survive
Old 11-16-17, 10:23 PM
ChronoR
ChronoR's Avatar
Do you have winter tires with useful tread on it? If not, that's the very first thing you need to go get if you plan to drive in the snow at all.
Old 11-16-17, 10:33 PM
Htony
Htony's Avatar
Even with set ofo winter tires, without LSD, it'll be tricky. Couple sand bags in the trunk may help too.
Old 11-17-17, 03:29 AM
MustangSal
MustangSal's Avatar
Tire chains (or snow chains).
Old 11-17-17, 04:59 AM
pseconds
pseconds's Avatar
Well, my question was more about weight placement and amount. Winter tires are not an option at the moment.
Old 11-17-17, 07:40 AM
er34
er34's Avatar
Weight really makes very little difference in slippery situations, the slightly added grip is offset by the fact that your car has to work harder to get the increased mass moving. It could also make you more prone to spin out in turns, wears out your rear suspension faster, and less fuel efficient.
You don't need to spend 1000 to get winter tires, because actually ANY winter tire is better than all season due to the softer compound designed for the low temperatures..
I run Pirelli Ice Zero FR's and my car drives like a tank. Tirerack carries them for $162 a tire and that's a 19"! If you have 17" or 18" rims, you can find even cheaper options.
https://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=Ice+Zero+FR&sidewall=Blackwall&partnum=245HR9IZFRXL&tab=Specs
Just my 2 Canadian cents(worth 1.5 US cents)
Old 11-17-17, 08:28 PM
RXGS
RXGS's Avatar
Just get snow tires and you’ll be fine.
Old 11-18-17, 09:30 AM
joedaddy1
joedaddy1's Avatar
you are in MN.. it should be mandatory for winter tires for the cold/snow winters there...
best tip for driving in snow with a lighter RWD car for 10+ years... winter tires + full tank of gas fill-up the night before the big storm..
good luck..
Old 11-18-17, 01:07 PM
JellyBean
JellyBean's Avatar
What do others do?
Over the rear axle, right behind the back seats. If you place the sand further back you start creating a lever arm that will shift weight from the front wheels, and you need just as much traction up front as on the rear tires. But I'll chime in and suggest 4 snow tires too, please.
Coleroad
12-14-15 10:28 AM
ThumperPup
Wheels, Tires & Brakes Forum
10-25-15 09:53 AM
AJ@TireRack.com
01-27-15 12:09 PM
zig@tr
IS F (2008-2014)
15
10-20-11 05:15 PM
ToothDoc
Hybrid Technology
12-18-07 01:15 PM
Quick Reply: Winter Weight - RWD
