Can I use this BMW antifreeze in my 2016 GS350?
I have a bottle of this BMW antifreeze and was wondering if I can mix it with the factory coolant in my 2016 GS350?
I personally wouldn't risk mixing or using it . Coming from experience of owning a Tacoma and previous owner mixing green and red and I had to change the radiator from corrosion.
Use Toyota/Lexus or fluid made for ASIAN Vehicles. Sell/give that to somebody with a beemer.
http://knowhow.napaonline.com/choose...mport-vehicle/
You mean PINK!!
Red was pre 2005 and probably compatible but different ingredients.
Red is Long Life and Pink Super Long Life
Toyota Red,. LLC: Ethylene Glycol(107-21-1),Diethylene Glycol(111-46-6) Water(7732-18-5) Organic Acid Salt(532-32-1) Hydrated Inorganic Salt(1310-58-3).
Toyota Pink, SLLC: Water (7732-18-5), Ethylene Glycol (107-21-1), Diethylene Glycol (111-46-6), Sebacic Acid (111-20-6), Potassium Hydroxide (1310-58-3).
You mean PINK!!
I'm wondering why the OP needs to be adding antifreeze anyway...
You can't be cheap when it comes to a 60k car. At $20.00 a gallon or whatever it is just buy the right stuff and be done with it. I often wonder if anyone has drilled a hole in their IPhone 8 for headphones?! :}
What are you mixing cooling for to begin with? Do you have a leak? You might want to fix that before skinflinting over a bottle of coolant.... lol
