Vossen rim size help
Has anyone run 19x9.5 offset +28 in the front and 19x11 + 45 in the rear. I know I’ll rub on the inside slightly from what I’ve heard.
Vossen VFS 2 Rims
Tire sizes
235/35/19 front
275/35/19 rear
the ideal size for the GS would be 20x9 front and 20x10.5 rear but Vossen isn’t running a deal on this package so I had to settle for the 19s. Any input will help thank you.
Vossen VFS 2 Rims
Tire sizes
235/35/19 front
275/35/19 rear
hi, yes u will specially rear , U cannot run 11 in the rear of a GS max 10.5, but if u want my advise, I am running 19" now Stance forged wheels , I went from 20" because of the rubbing issue, so I have 19x9 front 38ET 245-40-19 and 19x10 rear 45 ET 275-35-19 and sits nice and flush and no gaps lowered on Tanabe and no rubs at all with ppl sitting in the back and going over bumps, now its all up to u , good luck.
NVRLAND (11-29-17)
Im lowered on tanabe as well. I already purchased the rims and tires. I did pull the plug on the 19x9 28 and 19x11 45. Vossen informed me that it will fit but will rub on the inside of the rear tire. Is the max on the rear of a gs a 10.5 and no way to fit an 11? Or has nobody tried it yet. Decided to go with 255/35/19 front and 295/30/19 rear with Michelin Pilot Super Sports. Hopefully I can get it to fit, I'd be disappointed if its impossible.
Hi , max tire size on a GS 285 and ur running 295 and with 11 wide , good luck , U will be rubbing it for sure ,and if Vossen told u will rub u will rub 200%, u are married to those now sorry to say.keep us posted ....
GregCanada (12-05-17)
