Quick Oil & filter??
Does anyone know the part # for the filter? Lexus parts says the A3 is not the correct filter and they get $15 for one. Seems a little pricey since it's a similar filter for my 14 RX. I would imagine someone here changes their own oil?
Some websites say it's an A1 and others are saying it's an A3. It's for a 2018. I would guess it's the same filter for 16 & 17 year models. Local parts guy acted put out since I didn't buy the car from their dealer.
You will want P/N 04152-YZZA1 engine oil filter for your 2018 GS 350.
2013 - 2015 GS 350 2GRFSE (GRL10/11/15/16) 306 hp: Engine Oil Filter P/N 04152-YZZA3
2016 - 2018 GS 350 2GRFKS (GRL12/16) 311 hp: Engine Oil Filter P/N 04152-YZZA1
I believe the only difference between the two is the 13-15 (A3) has an extra o-ring and plastic push piece to drain the oil from the filter housing before you remove it. The newer models don't have this feature. You remove the entire filter housing without draining it first. I have both filters (one for the Avalon and highlander and one for the GS) and in the future I will buy the older version (A3) for both cars and just not use the O-ring and plastic thingy.
edit: see below. The A3 is a taller filter than the A1.
I'll get one from the parts department when I pick the car up. Hoping it's the A1 since it's the same filter for my 14 RX. I don't know why my local dealer gets $14 for one.
You're GS 350 requires 0W-20 Synthetic engine oil. (The engine oil type is shown in the engine compartment and in the Owners Manual.) Engine oil capacity is 6.7 quarts with filter replacement.
For my 2017 GS350 and, my dealer used the YZZA5 filter.
This is for the 3.5L 2GR-FKS motor.
Looking around it appears the A3 and A5 are the same filter but the A5 has the extra O-ring and plastic thingy to discharge the oil from the filter before removal.
Mine is AWD.
i believe all the Toyota filters come with the plastic drain tube and 2 gaskets included anyway.
when I had a 10 es350, that used YZZA1 filter and that came with the extra parts as well.
i believe the YZZA5 is a slightly longer filter.
do know the GS oil capacity is 6.8 quarts of oil VS 6.4 quarts for the ES350.
