HUD Retrofit
#48
I'm assuming most people who keep asking have no idea how slow deliveries via ocean freight are from Japan.
Typically takes up to 4 weeks to ship and clear customs. Once I get the part, it should take a weekend to complete this project.
Hopefully it's worth the wait!
#50
Hey Eddie, where is the plug or pigtail that goes into the HUD projector at? I have a 2013 RX 450h and I took off the back part of the dash(the defroster nozzle) but cannot figure out which plug goes into the HUD projector? Thanks, Tim
#51
It's on the harness behind the center console navigation display. You'll see an unused connector wrapped around the harness that is intended for the HUD. The display is really easy to take out, it's literally two or four plastic screws on the trim, and two 10mm bolts on each side of the actual display. Should take 5 minutes max.
North (03-30-18)
#52
Wow Eddie thank you, so it's really that easy? Do I need some type of extension so the wire will reach the HUD projector up on the dash. It seems to me like it is a stretch to reach the HUD? Is it easy to thread the wire up to the hud from behind the Navigation screen? I have seen a used HUD from a 2010 RX 450h but was afraid to buy it as wondered if it would be compatible. I can buy a new one from Lexus for around $750.00. Thanks again Eddie!!
#53
#54
Eddie, thanks so much again, as far as the connectors, the one that connects to the switches on the trim is already attached to the blank plate on the lower rt side of the steering column where the 3 buttons go that control the HUD. I tested it and it is definitely energized so I think all I have to do is buy the buttons and change out the blank plate with them, is this the separate cable your are talking about? Sorry to be dense but just want to make sure I am on the same wave length. Tim
#55
I am going to take out the Nav screen tomorrow and look at the harness and I think this will make more sense as to what you are saying. I will look at the harness and compare it to the 2010 RX 450 HUD projector that is on ebay and see if it looks similar. I spoke with someone at my Lexus dealership and he said that as far as being compatible it did look like it was, however the guy at the used parts place said if it didn't work I could send it back. If it did fit the harness and it was a different configuration , it wouldn't hurt the car 's computer would it? Thanks, Tim
#56
North (03-31-18)
eddie420 (03-31-18)
#59
Hello Eddie, well I took out the Nav screen this morning on my RX 450h, and there was no extra plug that goes to the HUD, however there is a place it looks like you can plug in perhaps another plug that would go to the HUD, it is the white one. Unsure just wondered if you have encountered this. Thanks again for all your help!!!!
#60
Eddie I looked at the back of the Nav screen on the salvage car that has the HUD that I was going to by and it too only has 2 plugs coming out of the back. Odd it didn''t even have the extra white one? I know this one pairs up with one that has HUD as this came off the car where I'm buying the salvage part(HUD)? Guess I'm going to give up???
