HUD Retrofit
#121
What cable is it I need? I thought the cable plugged into the cluster; where does it plug.
#123
HUD Trim:
https://www.mylparts.com/oem-parts/l...bC12Ni1nYXM%3D
HUD Cluster Panel:
https://www.mylparts.com/oem-parts/l...MtNWwtdjYtZ2Fz
HUD Cluster Panel Buttons:
HUD Upper Bracket
HUD Lower Bracket
The parts I can't hunt down are the following:
- HUD Wiring That plugs into hud itself
- HUD Wiring that plugs into the switches
- HUD Brackets - Could you check the above to see if they're correct?
Mind helping a noobie out ?
Thanks!!
jonathancl (08-01-19)
#124
So far I have:
HUD Trim:
HUD Cluster Panel:
- HUD Brackets
Thanks!!
HUD Trim:
HUD Cluster Panel:
- HUD Brackets
Thanks!!
https://www.ilcats.ru/lexus/?functio...=2&language=en
Here is the wire, also in the diagram you can see were it plugs into:
8214930130
https://www.ilcats.ru/lexus/?functio...=3&language=en
The wiring for the switches is already on an existing harness in your car, secured with green tape behind were the switches go.
#125
Here are part numbers for brackets for the HUD:
8214930130
8214930130
So do these look correct?
HUD Upper Bracket
HUD Lower Bracket
HUD Wire to head unit
https://www.mylparts.com/oem-parts/l...pan-8214930130
Finally: How the hell did you know WHERE to cut? That's something that just dawned on me.
#126
HUD Upper Bracket
HUD Lower Bracket
HUD Upper Bracket
HUD Lower Bracket
Throw me like $15 and I can take the top trim off my dash, and trace the opening for you on paper. Using the speaker grills on both side to line it up.
#127
Had a member(who bought the upper dash trim) trace a template for me, I transferred that to cardboard, and made the cut, The cut doesn't have to be perfect since the trim covers it. I ended up making the hole bigger than the template to get the trim to fit correctly. I threw out my original template after holding on to it for a while.
did the part numbers above look right? Last piece I’m worried about is the HUD itself. I see a 2013 HUD on eBay but I’m not sure that will work in my car.
thnks!
#128
I'm not sure if 2013 will work on 2018. $220 for the HUD is a good price though.Might be worth the try, seller has a 30 day return policy. They have been trying to sell it for over a year. It was $400 when I tried to buy it, but they didn't want my offer. I ended up getting one for about the price it's listed now.
#129
Yeah those part numbers look right.
I just offered him. He would take 200 shipped. not sure if I want to gamble it.
also; do I need the “mirror” or whatever that part is on the top of the HUD that you linked from the part site or is that included on the HUD units?
#131
Was it all plug n play? I’m worried it won’t be pre programmed for my car. I came from the BMW world where everything needs to be programmed.
is there any sort of indication the HUD was turned on? I ordered all of the parts minus the HUD itself. I’m going to try to buy that cheaper used. Does it pop up on screen or anything nothing the HUD was turned on?
do we know if anyone has had to? Or done this later than 2013 MY?
#132
Thanks a bunch.
Yes, no programing
Is there any sort of indication the HUD was turned on?
As soon as everything is plugged in and you turn it on the mph is projected on the windshield.
use the buttons to turn up the brightness or move position.
Do we know if anyone has had to? Or done this later than 2013 MY?
@eddie420 installed the 2013 HUD on his 2015, no issues.
eddie420 (08-01-19)
#133
I'll keep this all in one post in order for future retrofitters to see.
My Car: 2018 GS 350 - F Sport AWD - NON HUD Model
HUD Trim:
PN: 55548-30210-C0
HUD Cluster Panel:
PN: 55404-30A70
PN: 84120-30040
HUD Upper Bracket:
PN: 83166-30100
HUD Lower Bracket:
PN: 83166-30130
HUD Wire to head unit:
PN: 82149-30130
4X of Each of the following Bolts:
PN: 93568-55016
https://www.mylparts.com/oem-parts/l...rew-9356855016
PN: 93568-55014
https://www.mylparts.com/oem-parts/l...rew-9356855014
HUD Unit itself:
EBay - Bought a non-color 2013 GS HUD
Cost Breakdown:
- Used HUD unit from eBay - $220 Shipped
- All new HUD Trims / Parts from MYLParts - $250 Shipped
Total cost as of 8/2/2019 - $470
8/2/2019 - All parts ordered - Await Shipping
HUD Trim:
PN: 55548-30210-C0
HUD Cluster Panel:
PN: 55404-30A70
PN: 84120-30040
HUD Upper Bracket:
PN: 83166-30100
HUD Lower Bracket:
PN: 83166-30130
PN: 82149-30130
PN: 93568-55016
PN: 93568-55014
HUD Unit itself:
Cost Breakdown:
jonathancl (08-16-19)
#134
HUD Trim:
PN: 55548-30210-C0
HUD Cluster Panel:
PN: 55404-30A70
PN: 84120-30040
HUD Upper Bracket:
PN: 83166-30100
HUD Lower Bracket:
PN: 83166-30130
PN: 82149-30130
PN: 93568-55016
PN: 93568-55014
HUD Unit itself:
Cost Breakdown:
HUD Trim:
PN: 55548-30210-C0
HUD Cluster Panel:
PN: 55404-30A70
PN: 84120-30040
HUD Upper Bracket:
PN: 83166-30100
HUD Lower Bracket:
PN: 83166-30130
PN: 82149-30130
PN: 93568-55016
PN: 93568-55014
HUD Unit itself:
Cost Breakdown:
