Seat Heater Buttons...
2013 Lux package. I used Carista to set mine to manual and prevent the auto "turn down". Mine also stay on whatever they were last set to when the car is cut off and then on again. They maintain the settings on each side, heat or vent at whatever level I left them. I agree it would be annoying to have to set them each time the car is turned on.
Originally Posted by obadea
Hi, this is very interesting, mine does NOT remember if I left them ON when turning the car off. Do you mind telling me what MONTH the car was made? I got mine 04-2012, so it was one of the first ones.
My 2013 seat heaters remain in whatever heat position I set them - they do not change, which is how I like it. Also, when I turn Off the car with the seat heaters On and come back, the seat heaters come back On in the same heat position I had them in, which is how I like it. To my knowledge the personal seat heat settings have never been changed.
Thank you. Most likely that was changed, shortly after the car came out. I just got the 2014 buttons from ebay. Once they get here, I will attempt to replace them and then see if the auto / manual mode can be enabled directly via the buttons, and not have to use the carista app.
2jS160 (02-01-18)
super late update but thought i could add to this.
2015 with auto feature will plug up to the 2013 without auto feature but the auto feature will not work.
just use the carista app and change the setting under climate controls. switch it from auto to manual.
peasodos
11-23-21 09:11 PM
bclexus
01-19-19 04:37 PM
