Hi guys. Got a question for you all, which gen of IS wheels would you guys choose to put on a 4GS between the 2IS and 3IS wheels? Nebula grey exterior so keep that in mind. Also what tire size would you guys run on these for the 4GS?
Reason: Needed to add another question
With these options I would go with the 3IS wheels, even though I think at least 19" (GS F Sport, GSF, RCF, RC F Sport, or ISF wheels) would look better haha. Just check on whether they will fit. I could be be wrong but I believe I heard somewhere that only the IS350 wheels fit our GS, but again I could be wrong. As for tires, I'm not sure about that but probably the stock GS 18" sized tires would be best - whatever that size is.
odd question but i'll play.
3GS for sure as it will not age the look of your 4GS as badly. 2IS is just too old of a design, lacking the brushed or darker look for the newer cars.
keep in mind that outer diameter of 4GS tires are larger than 2/3IS so your tires should have a larger sidewall.
compare your stock GS tire sizes and try to stay near it.
I do like the 19” rims you posted from the ‘10 Lexus IS F, but they are hard to track down in oem guise unless you order from the dealership. All the ones I’ve seen for sale on the net are replicated. I’m done with replica wheels they crack and bend to easy in cold climate states.
I figured the OEM are hard to find. Yeah I agree that all the ones I've seen for sale online were replicas and you can easily tell. I'm definitely not promoting the replicas!
And this is a different pic of the same car and wheels I posted from an Auto Spies article on the 2010 ISF
well then.... i might consider those, they are very nice. I wanted to stick to 18’s since im paranoid about potholes. Im in canada and driving around here youd think it rained basketball sized meteors daily what with all the craters here.
