Sway Bars AWD
Does anyone manufacture sway bars for AWD?
Have a GS350F AWD and need to reduce the body roll.
Stock suspension, not lowering with springs or coilovers.
Can't seem to find anything from TRD, Tanabe, etc.
You can get some lowering springs to help.
Then Cusco makes an engine chasis bar.
-Josh
-Josh
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
raygun17 (02-20-18)
Tanabe F sport sway bar
Can't say if these are any good or not. Maybe you can ask for a comparison of rod stiffness, diameter to help decide if it will be worth it--I can't seem to locate any figures on stock vs. aftermarket.
I thought the F-Sport already came with upgraded sway bars. Lexus definitely used to sell them for the 3GS.
Thats what aftermarket parts are for ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
-Josh
-Josh
__________________
Orange County, CA
Orange County, CA
-Josh
__________________
Orange County, CA
Orange County, CA
nop go ask them whats the thickness and etc and compare to the oem f sport sway bar, cause I remember right non of the aftermarket sway bar makes a difference even for the trd sway bar. I think long time ago some1 ordered the trd sway bar and I think its the same thickness as the oem f sport sway bar just the bushing is different that's all. i'll be interested if ultra racing sway bar makes a difference.
eddie420 (07-02-18)
I researched extensively on anti-sway bars for the GS when I got my car. I believe I narrowed it only down to 1 or 2 companies that made it for our cars. It was a really hard find because even though they existed, no one really advertised them because of the low demand. Everything was special order. If you search the forum under my name, I'm sure you'll find my original posting. I forgot the name of the bar but I ended up buying it and the result was excellent! Just a word of caution, the mechanic book rate for the installation of the rear is like 15+ hours (requires removing the entire subframe). But my mechanic was able to install it by just lowering the subframe without removing, and then sqeezed the bar in from there.
Here's the bad news. There are no anti-sway bars for the AWD... they are only available on RWD.
