2013 Dead Battery after 3 wks parked
When I tried to start the car after 3 weeks in the garage, I got nothing - no clicking, no door lights, not even the flashing red alarm ON indicator. The battery is the original (car manufactured in Oct 2012), so it's likely to be shot. I assume the car hasn't gone into some "sleep" mode, from which it needs to wake up???
Anybody have recommendations for what battery to get/ where to get it - obviously not Lexus OEM. I want to make sure I get the right rating, and physical size - I don't want to have to "improvise". I've changed batteries in other cars, but never this one - any special tools or techniques needed?
Lexus has a replacement battery made by Interstate at a very decent price, which comes with an 84 month warranty in which the battery is replaced at no-charge if it fails within 2 years and pro-rata thereafter. The Lexus Part Number is: 00544-MF240-575
It is recommended that once a battery becomes two years old it should be load tested once a year to determine if it is still healthy and dependable. National Tire & Battery (NTB) will load test your battery at no-charge. It can be done in their parking lot in just 5 minutes.
The glass mat technology is a way to put the cells closer together and increase the CCA, but in warm/hot climates there is a much higher likelihood that batteries made with closely designed cells using the glass mat technology will short out compared to a lower CCA with increased spacing between cells.
If you are located in a cool/cold climate area CCA is important, but if you are located in a warm/hot climate area CCA is not important and you are much better off using a lower CCA with greater spacing between cells.
hziemba (02-19-18)
That is EXCELLENT advice. I replaced mine after 5 years and got the Lexus OEM Interstate battery. Got the battery and a complete electrical checkup for about the same price as I could buy a decent non-OEM replacement that would have required modification of the battery case for the non-OEM to fit properly. Not worth the hassle. Get the OEM battery. Great battery with an excellent warranty.
viperr (02-19-18)
I was quoted $160 for the new battery and installation at a Lexus dealership in NJ. I ended up going the aftermarket route (Delphi brand) and only saved about $40. When I do need a new battery, i'll likely go the dealership/OEM route since its not too much difference.
viperr (02-19-18)
A Group 24 battery case size should be: 10 1/4" x 6 13/16" x 8 7/8
You may find some battery makers that list their Group 24 battery size as [say]: 10 1/4" x 6 7/8" x 8 3/4" which should be okay and will fit the battery holder just fine without any problem. That said, there are some battery makers that have larger dimension Group 24 batteries that likely will present a problem fitting in the battery holder. I've seen one that is longer and measures: 11" x 6 7/8" x 8 3/4".
hziemba (02-19-18)
You are right. You'd think that a Group 24 battery would be one, and only one, dimension ... but that is not the 'case' (excuse the pun).
Thanks for those numbers. I've ordered a Bosch, Platinum Series AGM, Group 24, with actual dimensions of Length (in.)10.25, Width (in.) 6.81, Height (in.) 8.87 from Pep Boys that is on sale online for $142.49 (25% less than in the store). Picking it up at the local store tomorrow. Glad to know that it'll fit without any mods. I also like the fact that the warranty is 48 month, without pro-rating.
