My radio works, but no sound
Old 02-26-18, 09:01 AM
Inside2
Inside2's Avatar
Angry My radio works, but no sound
Hi ,
Anyone experience the audio problem with the GS350 ,my amp is PIONEER AMPLIFIER 86280-30670,My radio works, but no sound, the unit won't let me go into the sounds and adjust the bass or treble. Already checked the fuse and that wasn't it
Is possible to check the amplifier and how i can check if the power coming to the unit
Please help
THANK YOU
Old 02-26-18, 01:46 PM
jonathancl
jonathancl's Avatar
Did you check the cables? Curious that it won't let you adjust output settings, could be as simple as a connector not inserted all the way.
Old 02-26-18, 01:56 PM
Inside2
Inside2's Avatar
Yes, I did check the cables and connectors pull out the amplifier too, strange everything works fine then I wash the car and park in the garage for the week and this Saturday I start and just no sound?
Old 04-16-18, 09:32 AM
mikesd1980
mikesd1980's Avatar
Any updates on this? I'm starting to have this issue. 2014 GS350. I hear a stratching sound than it goes out. Some times music goes in and out. So far this has happened on fm/am radio and ipod.
Old 04-21-18, 04:19 PM
Jojose
Jojose's Avatar
I was able to fix it, just opened up the amp, cleaned it a little, pushed the button that says push and connected it back. Turned the car to find the audio working.
jonathancl (04-23-18)
Old 04-21-18, 08:07 PM
badman5
badman5's Avatar
I have this problem myself. Does your unit display the volume when you adjust volume? If no, then it possible the ampp, if yes, then its probably a loose connection that's affecting all the speakers so near the amp itself.
SuperGuest
09-27-23 03:13 AM
Inside2
07-02-21 06:43 PM
galtom
RX - 1st Gen (1999-2003)
06-30-18 09:40 PM
WHY1
06-22-15 11:17 AM
427cobra
10-29-14 08:33 AM
Quick Reply: My radio works, but no sound
