2015 GS350 / Options question
Hey folks...I'm looking at picking up a 2015 GS350 F-Sport...This will be the 1st automatic car I've ever owner (GTI-VR6, A4, WRX, 335xi Coupe, V6 Accord Coupe) are my last few. The GS seems to have the fit & finish and growl of the Germans, and (hopefully) the maintenance cost of the Japanese cars. But I've run into a snag here...The one I'm about to pull the trigger on has me confused regarding options. The listing SAYS it has the cold weather package, and the controls to the left of the steering wheel has the steering wheel warmer, but it clearly does not have the headlamp washers, or the associated interior button.
Is it possible it has the CW package, just not the headlamp washers? Or is there another package that ISN'T the CW package that has the heated steering wheel only? I read the well put together post stickied on the home page, but don't see this question brought up. Any thoughts? Thanks!
Do you have this raised box in front of your headlights?
If you don't have this, that means you don't have headlight washers. I have them and used it maybe once, honestly I think it's unnecessary, unless you go months without washing your car.
Heated steering wheel is a STANDARD part of the F-sport package I think.... so that car might not have CWP. I just looked at my (2015 F Sport AWD) sticker and the heated wheel appears as part of the F-Sport package item on the sticker.
FWIW I have noticed that either due to a "package conflict" (not available) or whatever, its difficult to find a 2015 F sports that have things like CWP, LKA, DRS, etc. Most of the cars its a matter of choosing ML sound or no ML, everything else is otherwise the same on a lot of the cars out there.
I also agree with Peasodos, the feature is kinda worthless anyways. Even with all the guk on the roads ive washed my car here and there and that usually keeps the lenses clean enough. A can of stoner invisible glass in the trunk and some paper towels is enough to get you buy if you can't get her washed on a semi regular basis.
-Mike
-Mike
Thanks for the input! I agree, I had headlamp washers on my A4, preeeety sure I never used them. I was just trying to get an idea of what the pricing should be. The car has the ML sound and is $1200 cheaper than another that I'm looking at that HAS the CWP but no ML sound.
Seems with all the variants around packages even the dealerships can get things confused. I'm guessing the heated steering wheel and heated front seats is what prompted them to advertise CWP...I will use that as a bargaining chip when I go in.
https://www.clublexus.com/forums/gs-...-pictures.html
its useful on long drives in snowy conditions, or wet/muddy conditiond
The cold weather package changed a little bit over the years.
Take a look at the 2015 GS Lexus Brochure page 22 to see what the package includes:
http://www.lexus.com/documents/broch...S-Brochure.pdf
"COLD WEATHER PACKAGE (Standard on GS 450h) Heated steering wheel // High-intensity interior heater // Headlamp washers (GS 350 RWD; standard on AWD; not available on GS 450h) // Windshield-wiper deicer // Water-repellent front-door glass // LED headlamps (GS F SPORT)"
It looks like the headlight washers are already standard on the 2015 AWD's and the package does include the heated steering wheel.
There is no button for the headlight washers. They will operate every so often when cleaning the windshield. The manual goes into detail on how they work.
The windshield deicer may not have a switch either. On my 2018 that is turned on through the nav screen/settings.
Interestingly the 2018 GS cold weather package only includes the headlight washers, windshield deicer and water repellent front door glass. The heated steering wheel is a standalone option but I think it was only $150.
No mention of any high intensity interior heater on later models, I wonder if they got rid of it or if it's standard. I think all the new safety gadgets are standard on the 2018's, at least on the F sports.
Ahhh...so maybe that's what it was. No CWP, but they added the heated steering wheel.
So none of the following (other than what's been added as an option):
Heated steering wheel (ADDED)// High-intensity interior heater // Headlamp washers // Windshield-wiper deicer // LED headlamps (GS F SPORT)
Other than going to Climate in the menu, is there an externally visible way to tell if the Windshield-wiper deicer is installed? A thin metallic strip or something? Again, likely a feature I won't too often...but good to know if I have
Just like to make sure I'm getting the most bang for the buck on used car purchase, I swear car manufactures make you get a Masters in figuring out their options before you buy. I'm gonna end up with paralysis by analysis. Ok, that's not true, I'm hoping to buy today...15 GS350 AWD, F-Sport, ML, CPO, 28k miles @ $34.5k OTD.
