Trunk Springs Weak?
Nope, no extra holes on a 2013 GS. I can probably drill some but there aren't any additional ones that will fit. And the pins are this type, no tool will make them easy to extract. Just jab a screwdriver in there and pull.
http://assets.suredone.com/1704/medi...n-qty-20-4.jpg
Pictures of covers pulled back. Neither side has an additional hole. I can pull them out with my bare hands but there's not alternative spots to put them. I did not make the scratches
Passenger side.
Driver side
Passenger side.
Driver side
My car (2013 GS 450h) looked like the top picture when I tried to make this adjustment. Isn't the top picture the drivers side? Anyway I tried using the round holes in the picture and neither helped. In fact one of the holes made it so the trunk lid would not stay open all the way. I put the tension rod back in its original position and gave up. I would still like to fix this if any one has other ideas. I keep getting hit in the head when loading groceries on a windy day.
schack (03-29-18)
Actually, I'm surprised to find a spring in a Lexus. I'd have expected gas charged cylinders for a smooth lift action, like a hatch on an RX.
Last edited by Knucklebus; 03-28-18 at 02:27 PM. Reason: Added thoughts on lacking a gas cylinder
Please see below pic I circled in red, on the driver's side there are two holes to install the trunk spring into. If you install it into the hole I have it in the pic the trunk lid will not fall down. I had the same issue when I bought the car used. I just adjusted the trunk lid spring and problem solved.
jonathancl (05-17-19)
Mine is the same
The trunk on the new ES 350 has a small gas strut mounted to the shock tower and the base of the hinge on one side that lifts the trunk smoothly to fully open when you click the button to open it.I'd love to figure out a way to retrofit mine to do the same vs what some others have done and get all the parts for the electric trunk opener.
My 2015 GS 350 is the same. However, I have the F-sport with the factory spoiler, and while I've never had a problem with my trunk falling on my head I do wish there was more tension.
Yup!
Yes mine is anchored at the top position, giving it more lift. One of these days I'm going to my dealer and taking pics and measurements of the gas lift strut in an ES trunk... 😊 Maybe I can figure a way to retrofit one. It provides such a nice, quiet and smooth opening.
Im2bz2p345 (01-26-20)
slickgt1
12-08-06 10:26 PM
