Paint Protection Film Installation
Former Sponsor
Lol. Definitely didn't want to make it more confusing. If it were me, I would remove the door edge trim and install the film to wrap around the door. At that point, you could determine if you want to put the factory door edges back on.
Well, we offer a 3 day class for PPF, and most often, the installers that come through are going to need additional practice before they get to the point of being able to sell a job. Don't expect professional level results on a first time DIY PPF install. The good news is white is about the most forgiving color when it comes to installation flaws. That said, you will need a very clean environment and will want to not wear anything that sheds (blue jeans for instance).
-Jason
-Jason
Sure bud. When are you planning on doing yours? I have a busy work schedule and the car will need to be out of commission for a few days since the first 24 hours are critical in keeping the chemicals cure. Plus I need to thoroughly pressure wash and clay the car. Time consuming. If AeroTect has some advice before I jump into this since he seems very knowledgeable, that'll help us both!
The following 2 users liked this post by AeroTect:
eddie420 (05-01-18),
Im2bz2p345 (05-01-18)
Nope. Have a lot of wiring and mechanical projects on the car on going. PPF requires an indoor area away from the sun (e.g., garage, storage tent, etc) and from any debris. I turned my garage into a guest room so I'm SOL until I can finish the remaining projects I have on going. By then I'm sure I'll need to do some paint correction before applying the PPF. I would say you should just go ahead and do it. Take some water and isopropyl alcohol, mix it in a bottle, and apply the PPF to the hood of your car. You'll see it's quite easy to work it, especially for a large surface like that. Even better for us since our cars don't have any hood scoops lol.
So I plan to install the PPF this weekend. Do you recommend leaving an eight of an inch gap between the PPF and the edge of each panel? Or do you recommend letting the film overhang and then once it dries, to wrap around the edges for full coverage? I bought the 3M PPF Knifeless Tape because I thought I was going to leave an eight of an inch gap but now I am wondering if I should go for full coverage? I know wrapping all the way can cause the film to lift if the surface is not prepared well. Just looking for some expert insight. Thanks!
eddie420 (06-14-18)
Where can I buy new door edge film guards? Mine are dirty and actually have dirt trapped underneath so it looks horrible. It looks kinda like mold and mildew buildup. Will post a pic tomorrow afternoon. I was also going to apply some of that clear 3M film to the front edge of my hood and lower region behind the wheels where rocks and debris kick up from the tires. My wife's Acura MDX has it and it's kinda grown on me. I can't use the same 3M film because the door edge guards aren't straight.
Former Sponsor
Wrap it. Just clean the areas well where you will be wrapping it. It should also be a smooth painted surface. Also, on corners, you will need a slight relief cut so the film doesn't overlap itself on the wrap.
eddie420 (06-15-18)
Has anyone tried using the generic door edge guards on their GS? Thinking of applying these white ones:
https://www.ebay.com/itm/Trim-Moldin...oAAOSwoydWkSS-
Not crazy about the clear because I have a white car and the dirt outline is always highly visible. The driver side actually has mold or something growing underneath. However, the grey car looks fine but that's because the grey hides dirt alot better. This is what the factory door edge guards look like now. Thinking back, maybe I should've bought a black car...
front driver side door edge guard
front passenger side door edge guard
rear driver side no door edge guard
rear passenger side door edge guard
Trust me, you don't want to go down the eBay route... I tried that and it the results look bad lol. I ended up buying the factory door edge guards for $80 and they look and function awesome. No dirt line with them.
Black cars are the worst to maintain. Let me retract that statement... they are a nightmare, especially if you have OCD tendencies.
Let me see a better picture of those brake calipers. Do they have "F-Sport" on them? Look nice.
Also, I didn't install the PPF over the weekend as planned, the weather got up in almost triple digits. Proper install should be between 60 and 90 deg F. Hopefully next weekend is better lol.
Lettuce
Automotive Care & Detailing
01-16-04 09:27 AM
