Headlight Retainer Part#
Old 06-25-18 | 07:43 PM
r3dl4b3l's Avatar
r3dl4b3l
Default Headlight Retainer Part#
Anyone know the part# or where I can get a replacement headlight retainer adapter? I was changing out my HID bulbs and the retainer clip chipped off both sides of the plastic that was supposed to keep it in place. Hate to buy a whole headlight assembly for just one small part. I attached a photo of the headlight assembly with the part circled in red. TIA!
Old 06-26-18 | 12:33 PM
Kevin4GS's Avatar
Kevin4GS
Not sure what exactly you are looking for but I hope the link below helps,
http://www.oemlexusparts.com/2013-le...lamps-8947025/
Old 06-26-18 | 09:22 PM
r3dl4b3l's Avatar
r3dl4b3l
Thanks Kevin. I called the dealership and there's no part# for it since it's apart of the projector lense. Looking for someone to hopefully repair it so I wouldn't have to buy a new assembly.
Old 06-27-18 | 04:32 AM
eddie420's Avatar
eddie420
I don't think that's true... let me check and get back to you.
Old 06-27-18 | 04:37 AM
eddie420's Avatar
eddie420
I'm at work right now but see if this helps you out, there are four images: http://jp-carparts.com/lexus/partlis...ype=5&fig=8101
r3dl4b3l (06-27-18)
Old 06-27-18 | 08:21 AM
r3dl4b3l's Avatar
r3dl4b3l
Thanks Eddie! I found the part but its not listed on the website for some reason. It is on the last image (4) part number 811377A for the left hand side (driver side). Could you check to see if you have this in stock or able to order?
Old 06-27-18 | 09:19 AM
eddie420's Avatar
eddie420
I don't work for Lexus LOL. I am just a regular CL member. Looks like the part you mention is actually 81177A (not 811377A)? If not, then this link is going to be wrong: https://www.discountpartsmonster.com...amp-8113747660
Old 06-27-18 | 09:21 AM
eddie420's Avatar
eddie420
Take a look at this one. It is cleaner: https://www.megazip.net/zapchasti-dl...dlamp-17922312
Old 06-27-18 | 09:48 AM
r3dl4b3l's Avatar
r3dl4b3l
Thanks Eddie! Sorry I thought you worked at Lexus
Looks like the part is unsearchable, 81177A/81137B reference the entire headlight assembly. I sent an inquiry to JP Car Parts for the item, hopefully they come back with a part number that I can order from. I'm going to go to the salvage yard and look at a headlight and see if it comes off the projector.
Thanks for the help!
Old 06-27-18 | 10:16 AM
eddie420's Avatar
eddie420
I already gave you what 81177A translates to. It's P/N 81137-47660.
r3dl4b3l (06-27-18)
Old 06-27-18 | 12:47 PM
r3dl4b3l's Avatar
r3dl4b3l
Thanks Eddie! I'll check it out at the local dealership and report back in case anyone else needs this part one day.
Old 06-27-18 | 01:52 PM
r3dl4b3l's Avatar
r3dl4b3l
Called the local Toyota/Lexus dealers and also 5 online vendors and all of them said 0 stock in the entire country. Will take a trip to the junkyard and look at a busted one and see if I can pull the part instead.
Old 06-27-18 | 02:19 PM
eddie420's Avatar
eddie420
Hahaha, yeah... that happens quite often with some obscure parts. You'll see in one of my threads I had to wait 14 weeks to get a part shipped from Japan. It's rare but it happens. Better off finding something at a junkyard or ebay.
Pachino
08-07-20 11:35 AM
charleymd
08-09-18 09:17 AM
TriniLex
RX - 3rd Gen (2010-2015)
05-02-18 08:16 AM
BubbaJeffy
11-12-16 02:10 AM
Leowaxx
10-01-14 01:05 PM
