Battery: Aver Life?
Old 08-09-18, 11:02 AM
praetor
praetor's Avatar
I can't speak for cars but I trickle charge the batteries on my motorcycle. My batteries lasted 7+ years. I only rode a few months out of the year as it's cold in Chicago and they sat in an unheated garage all winter.
Old 08-09-18, 11:39 AM
buckets
buckets's Avatar
might be a little off topic, but has anyone have any issues with their clocks? mine is always 24hrs behind and i got so tired of correcting it, i wanted to get a new battery when i took my '13 in for an oil change hoping that'll fix the issue but the tech told me the battery was still ok...
Old 08-09-18, 12:04 PM
GregCanada
GregCanada's Avatar
I see what you did there...
Old 08-10-18, 12:11 PM
2GR
2GR's Avatar
All good info. I will get a load check this week.
Had a friend who's OE battery developed a nasty blue mushroom on the positive terminal within a week...real messy cleanup. (2012 Camry)
Old 01-04-20, 11:28 PM
DavidMosby
DavidMosby's Avatar
Get the largest battery that will fit and be sure it is AGM. Walmart has the best warranty for 5 years but limited availability. Advance Auto has 25% off and you can use it for the AGM batteries. Read up on them and you will never get plain lead acid again. Get a Ctek charger and charge it once a month. This will desulfate the battery. The battery might outlast you.
Old 01-05-20, 08:12 AM
Nalod
Nalod's Avatar
I had a 1989 420SEL with battery about double the size of normal. Looked like a marine battery! I was not aware that batteries can arc (explode) upon starting. This was car was 7 years old, maybe had 60k miles on it at the time. Lucky no electronics were damaged.
Now I replace every 5 years. The occurrence freaked me out.
Old 01-05-20, 08:22 AM
swfla
swfla's Avatar
Received 1,272 Likes on 984 Posts
Originally Posted by bclexus
Who created this chart? I lived in FL for 30 years and found that extreme heat is a killer.
Old 01-05-20, 08:26 AM
swfla
swfla's Avatar
Originally Posted by praetor
I'm on year 6 with my 2013 GS, I plan on replacing it before winter. I've had good luck with DieHard if Sears is still around. If you want a battery that will last and stand up to extreme conditions get an Optima red top battery. Yellowtop is overkill unless you have amps running.
According to Scotty Kilmer on Youtube, Optima has changed their production methods and are no longer producing great batteries. Too bad.
Old 01-05-20, 09:47 AM
bclexus
bclexus's Avatar
Received 2,098 Likes on 1,494 Posts
Correct, heat is a killer of batteries...as the map indicates that heat is.
Old 01-05-20, 06:43 PM
swfla
swfla's Avatar
I read a bit (I'm no expert) about AGM batteries as you suggested and it appears that they have a different charge rate than lead acid. It can be a real issue for battery chargers that don't have an AGM setting. more importantly, several mentions of car computers indicating issues/codes/check engine lights because of this different draw. Considering how computer centric all cars systems are these days, I'm not surprised. I'm not saying it would be a problem with all cars, but it'd be $$$ out the window if it were. AGM does sound great overall otherwise.
airdzi
16
06-07-17 09:07 AM
dxerg3770
ES - 6th Gen (2013-2018)
46
03-15-15 08:16 AM
WylieKylie
05-18-14 09:39 AM
bacardi
03-10-11 10:13 AM
DaveN
02-03-08 12:00 PM
Quick Reply: Battery: Aver Life?
