Are all 2013-2015 F Sport headlights the same?
Bringing this from the heap. What are adaptive headlights versus AFS headlights? I have a 2013 450h, so I want to do what Peasodos did and put the Three beam headlights in. Thanks.
AFS and adaptive headlights are the same thing, the headlights turn slightly with the steering wheel to improve visibility around corners.
There are the base HID headlights that are just auto leveling.
The AFS HID that are adaptive and auto leveling.
Then LED headlights that are adaptive and auto leveling.
Thanks Peasodos as always. I think I am going to do an F-sport grille thing too similar to what you did before you converted to the MMC front bumper. All this will occur in the fall as it is too hot in Florida right now. Here is my first of many questions. I am acquiring the LED headlights, the new ECU, and the No AVS switch next week. Headlights are used of course so need to evaluate their condition. The no AVS switch, why do I need that? Don’t I want headlights to be AVS? My current lights on the 450h are the HID auto leveling. Any suggestions on getting the upper and lower f-sport grille. Thanks again.
Ok,I broke out the owner’s manual for this No AFS switch thing. The manual shows a switch below the right side of the steering wheel. Of course there is not an open spot on the dash for this, so a little on my knees looking, and it appears this switch basically would go under the dash near the OBD port. Can someone confirm this is the case? But my question remains, why would you want to ever turn these off? And if you did, the location of the switch is so inaccessible, how could you do this while driving? Inquiring minds want to know. Thanks
I had the AFS on my previous 2013 lux package. Yes, the button is under the dash near OBD2 port. As to why you would want to turn them off, my guess is that is for the case of one of the lights malfunctioning. It may give an error message if one of the aiming motors breaks, or something. In that case maybe you can turn off AFS and they function like regular headlights and no error message. Just guessing.
@CottageChz is correct you will get an error on the dash without the switch. The system will detect a fault. The switch is the cheapest part of the mod and the plug for it is already there taped to a harness behind the blank switch.
- - G T V I P - -
I have a 2013 F-Sport (No AFS)
Ive been tossing up the idea of upgrading to the hybrid LED headlights but have not gotten a solid answer as to whats needed. Ive been searching through the various threads and it seems they are not 100% plug and play as they are in those with the Luxury package.
If I acquired the following, would this then make it plug and play without any errors?
* LED AFS computer: 89940-30270
* Switch: 84155-30020
Or would I need something else?
Thanks for the help!
~ JV
~ JV
~ JV
~ JV
Take the instrument cluster out, take it apart, put electrical tape over the AFS led from the inside, put it back together and in the car. Then the AFS light is out of sight and out of mind. I did this on my last car when I got the TPMS light and didn't care for the TPMS system.
There are a few people with f-sports that got it working, you have to search old threads. The mod is only plug and play with the non f-sport.
Not to second Peasodos cause he is the master, but I saw on YouTube someone just disconnected the AFS fuse for the light. Don’t know if that would work. I think it was on an IS-F so a bit older.
- - G T V I P - -
Thanks for the info Peasodos,
I was doing alot of researching and some say the swivel will remove the AFS error. I myself have no problem removing the cluster and blocking the AFS light, I did that on my previous 09 IS350 when I upgraded to the newer style LED DRL headlights.
Now to find some affordable LED headlights >
~ JV
~ JV
Well I did receive my headlights, though you get what you pay for is the saying. They were cheap, but it will be a project to clean them up and fix two broken tabs. How do these things get broken tabs anyway? Aren’t there just screws holding them in place? It is like someone is ripping them out without taking out the screws. I am dubious that they will even work. Does anyone know of a way to test headlights without installing them? I mean I do not even see the LED bulbs. It doesn’t look like there is a way to replace them either. I wish I was Russian guy or Peasodos. I am under CPO warranty till next May, so I don’t want to take off bumper and install everything, plug them in, turn on the lights, and blow circuits all over the place without first trying to see if they work. One of those back burner things to do if nothing else is going on in the world. Like now😁
one of my headlights are from an accident car. I screwed in replacement tabs and fixed one broken tab. The head works perfectly fine.
there is no way of testing it really without installing and the LEDs you can’t replace. They are designed to last a very long time probably outlast the car.
i recently just put these headlights on a f sport with no afs. my driver side headlight is aimed correctly but passenger side is way off. i did a manual adjustment on both sides to try to even out the gap but still looks off..i adjusted the driver side all the way up and passenger side all the way down. it would not turn anymore as it has reached its limit. my question is that if i get the ecu would it readjust the aim as well? im thinking it cant readjust unless theres some other internal electronic adjuster otherwise manually it is maxed out..i feel like im blinding people in front of me as opposed to oncoming traffic since my passenger side is the one that is aimed very high
