Frankenstein 2015 GS Head Unit into a 2013 GSh
Old 08-31-19 | 09:11 PM
  #46
peasodos's Avatar
peasodos
Originally Posted by itsRaymond
@peasodos
Did you ever get the rearview camera to work yet? Or perhaps switched to a 2016 unit?
No, and I don't need a rear view camera, have the parking sensors. Switching to 2016 requires rewiring for the 2016 infotainment controls in the center console.
Old 10-02-19 | 02:11 PM
  #47
peasodos's Avatar
peasodos
Originally Posted by eddie420
When I sent you the 2015 wiring, I didn't really look what the changes were. I dug around a little, maybe some of it will help you.
2013
2015
2015 rear camera CANBUS goes from Pins 1 and 4 and taps into Pins 15 and 16 of the Network Gateway ECU and is the control signal that tells the camera to activate.
2013 Has a Network Gateway ECU but the camera is not tapped into the Network Gateway ECU on pins 15 and 16. I think it might be worth a shot to tap it how the 2015 has it, it's a low voltage communication signal so you won't damage anything (in theory). And if that does not activate the camera, then I'd say get the 2015 camera from car-part.com and replace the one you have. You'll just need to get connector.
@eddie420 Looking back at this now I'm going to wire those can bus connections and see if my backup camera works again. Thanks for the info, almost a year later now
Old 10-02-19 | 02:17 PM
  #48
eddie420's Avatar
eddie420
Ahahaha, I know you have been busy with all your other stuff (repainting bumper, etc.). Hopefully this works out for you. Keep us posted!
Old 10-03-19 | 07:51 AM
  #49
IntrinoX's Avatar
IntrinoX
Let me know if that works out.
I want the BeatSonic front camera module, but it only works with the 15+ head units.
Old 10-25-19 | 12:34 PM
  #50
peasodos's Avatar
peasodos
So I bought a used 2015 camera, wired the can bus lines to the network gateway ecu and wired the other pins to the back of the 12.3" display, didn't work. Instead I got the BSM light on the dash. I undid the mod and BSM works again.
RichardB23 (10-25-19)
Old 10-26-19 | 06:56 PM
  #51
aachowhan's Avatar
aachowhan
Please tell me how to fix the clicking fan! I have the same issue on my GS. It usually happens when it's cold.
Old 10-27-19 | 12:28 AM
  #52
peasodos's Avatar
peasodos
See this post and scroll downwards:
https://www.clublexus.com/forums/gs-...ml#post9825783
You have the disassemble the entire head unit, take pics along the way, and bag/tag the parts/screws, so you know how to reassemble everything.
This was the fan I replaced the stock defective one with:
Amazon Amazon
There are two fans so you issue could be with the other fan or both, only way to know for sure is to test the fans by itself outside the case, or just replace both.
Old 10-27-19 | 02:58 AM
  #53
peasodos's Avatar
peasodos
@peasodos
For 2016+ with full screen you have to change the 12.3" display to the one from the 2016, also the hand controls on the center console. There are actual hardware differences that prevent the 2013-2015 12.3" display from going full screen.
So yeah like the Russian guy did, it's doable, but a very expensive mod.
Old 10-27-19 | 03:56 AM
  #54
peasodos's Avatar
peasodos
oh snap I think I found a backup camera solution on Alibaba. It's made for 2015-2017 lexus, so maybe it will work with my 2015 Head unit. It connects right to the back of the 12.3" display and I just have to buy an aftermarket backup camera, possible better image quality than stock one.
https://roadpassion.en.alibaba.com/p...718e5e1d7ozVRa
Old 10-29-19 | 11:01 AM
  #55
Im2bz2p345's Avatar
Im2bz2p345
Sorry to thread jack, but @aachowhan , if you replace the clicking fan, could you PLEASE take photos along the way or better yet a VIDEO of the process?
It has sporadically happenes on my vehicle and I know @peasodos took the dive to rip open the entire stereo unit, but I just haven't had the time or courage But I may tackle this over the winter too.
~ Im2bz2p345
Old 12-27-19 | 11:40 PM
  #56
aachowhan's Avatar
aachowhan
~ Im2bz2p345
Will do, I'm thinking of getting the fan soon. Mine has been whining when starting up in the colder days.
Old 03-16-20 | 07:35 AM
  #57
Chungvatra's Avatar
Chungvatra
If anyone wants to do this mod, I have an extra set of this wire:
The only way to get this is to pick it of a 2015+ wiring harness.
Asking $50, to help recoupe the costs on my end.
Then all you need is 2x of these:
http://www.discountcarstereo.com/XMM-TOY.html
I'm living without the backup camera, not a big deal since I have the parking sensors. Maybe in a few years I'll score a deal on a 2016+ head unit and try hooking that up.
Do you still have this cable?
Old 03-16-20 | 08:20 AM
  #58
peasodos's Avatar
peasodos
No I don’t unfortunately.
Old 01-14-21 | 10:15 AM
  #59
NoMSGadded's Avatar
NoMSGadded
I have a spare video cable if anyone is interested in tackling this
Old 01-16-21 | 03:38 PM
  #60
eddie420's Avatar
eddie420
Please make sure to list it in the market place and post the link here for those that are interested! Thanks!
https://www.clublexus.com/forums/market/
Im2bz2p345 (01-16-21)
Quick Reply: Frankenstein 2015 GS Head Unit into a 2013 GSh
