Frankenstein 2015 GS Head Unit into a 2013 GSh
Old 09-13-18, 09:35 PM
peasodos
peasodos's Avatar
Received 2,229 Likes on 1,450 Posts
Default Frankenstein 2015 GS Head Unit into a 2013 GSh
I think upgrading 2013-2014 GS head unit to 2015+ might be possible.
Here are the pictures when I disassemble my head unit last year to fix a clicking fan.
Well the bottom half is related to the antenna's and the connection on the backside is the only thing that is different from 2013-2014, preventing someone from installing it.
Maybe I can take the bottom half of my 2013 and connect it to the upper half of a 2015+ head unit and Frankenstein a 2015+ head unit upgrade.
Left one is 2013, right one is 2015
2015+ Nav units have SD card slot for the maps, easy to upgrade maps, plus siri eyes free, full screen maps
I tried in the past to clone the hard drive to an ssd, but the 2015+ head units don't have the hard drive they load the maps from the sd card.
I just purchased a 2015 Head unit on eBay for $299 including shipping:
I have Mark Levinson sound system, but this unit doesn't have the logo in the middle, but according to jonathancl and twylie there is no difference in fidelity, quality, or volume.
Mark Levinson and non-ML head units are exactly the same except for the printed logo.
Worst case this doesn't work out I switch everything back and return the head unit for a refund.
The following 4 users liked this post by peasodos:
ChronoR (09-15-18), Im2bz2p345 (09-14-18), maveriCK.. (09-15-18), sam430 (09-14-18)
Old 09-14-18, 07:07 AM
Knucklebus
Knucklebus's Avatar
Very interesting stuff. As the owner of a 2013, I am cheering you on!
Old 09-14-18, 07:23 AM
jonathancl
jonathancl's Avatar
Well...this is an exciting possibility. Best case, you will still need to adapt the antenna plugs: they will be different even with your frankenbusiness.
I would be extremely surprised if these radios are as modular as you are hoping. Integrated solutions are almost always developed as a whole with many components changing from build to build along with the embedded software.
Whatever happens, please take tons of pictures as you go.
Old 09-14-18, 09:12 AM
peasodos
peasodos's Avatar
I'm hoping the ribbon cables that connect the upper and lower half are the same. Yes I will update with pics.
Old 09-15-18, 01:04 PM
swat1727
swat1727's Avatar
How do you get full screen? I thought that's only for 16+ GS... I would love to make it full screen
Old 09-15-18, 01:13 PM
peasodos
peasodos's Avatar
Chit your right. 2015 doesn't have full screen, oh well at least it will have a lot the features my 2013 doesn't have, that's if it works out.
sd card based nav instead of hard drive based nav, scrolling temps, ability for me to add the auto heat/cool, and free live traffic via HD radio.
Old 09-15-18, 11:48 PM
peasodos
peasodos's Avatar
Interesting, plugs on the back of the 2015 RX nav are exactly the same as the 2013 gs:
The 2015 RX nav is sd card based, gives me some hope for the mod
The plugs only change for the 2016+ RX
Old 09-16-18, 12:42 AM
LexusGS808
LexusGS808's Avatar
With the 2015 head unit, would this enable 2013 owners to have the updated Enform features? Such as remote start with subscription?
Old 09-18-18, 08:30 PM
peasodos
peasodos's Avatar
ok, this mod is dead.
The power and ribbon cable that connect the upper and lower parts are exactly the same, but the sd card is connected to the lower section.
The lower section is for inputs and the upper section is outputs.
Also three connectors on the back are different. They look like they are for the same thing, lexus just changed the connection. I boxed it in red below.
Unless you can find an adapter for these connections, it's not going to work.
Old 09-19-18, 04:34 AM
eddie420
eddie420's Avatar
I recall saying the same thing but somehow brought my project back to life. I have a feeling you will figure it out.
Old 09-19-18, 07:57 AM
peasodos
peasodos's Avatar
lol I've been trying to do something with my head unit ever since my thread of cloning the factory drive to an ssd.
Old 10-25-18, 09:50 PM
peasodos
peasodos's Avatar
I think I figured out the plug situation. Two of the plugs circled in red are antenna plugs. I think this adapter will work:
http://www.discountcarstereo.com/XMM-TOY.html
Stick the factory plug into the green end and the other part into the head unit.
The big green plug at the bottom connects to the back of the 12.3 display(blue part). I picked the part off a 2015 Lexus is dash harness, for cheap from a junkyard.
Old 10-26-18, 04:57 AM
eddie420
eddie420's Avatar
The thing with Toyota is they make connector changes so they don't screw up different year revisions on the manufacturing line. The wiring itself stays identical (in most cases).
A good example, specONE installed the touchpad on his 3IS, see here: https://www.clublexus.com/forums/is-...-in-a-3is.html
Old 10-26-18, 05:09 AM
peasodos
peasodos's Avatar
In this case it's two single antenna lines, wiring appears to be exactly the same. They changed the plugs from square to circle.
Also the plug for the display out. These changes apply for all the sd card based nav units across the entire Lexus and Toyota lineup.
The 2016+ head units is a different story because the mousepad interface changed and the usb in the front console is different plug. I posted to another thread some Russian guy installing the 2016+ nav and it was a lot of rewiring to get it to work.
Fingers crossed this works out for me.
Old 10-26-18, 01:48 PM
eddie420
eddie420's Avatar
Yes, I saw that post from you. I am looking forward to you getting this to work. There are quite a few people who love their 2013's but want the 2015 unit. This is the answer.
Quick Reply: Frankenstein 2015 GS Head Unit into a 2013 GSh
