Water pump replacement
That's right. It's an INSPECTION only item at all 30k intervals. It is suggested for replacement at 100k per the service manual.
FACTORY RECOMMENDED Service for 100K Miles /120Months
Print
- Check Installation Of Driver's Floor Mat
- Reset Oil Maintenance Reminder, if Oil was Changed
- Perform Road-Test on Vehicle
- Rotate Tires
- Inspect Visually, Brake Linings/Drums And Brake Pads/Discs
- Inspect Wiper Blades
- Inspect /Adjust All Fluid Levels
(Inspect sealed transmissions, transfer cases, and differentials for signs of leakage. If any leakage from a sealed component is suspected, it is recommended that you have the sealed component inspected by a Toyota dealer. Inspect power steering fluid (if equipped) and brake fluid level/condition. Inspect engine and inverter (if equipped) coolant level/condition/freezing point. Your dealer may recommend services (Dealer-Recommended Maintenance) based on inspection results.) - Replace Engine Oil And Oil Filter
(Reset "Maint Reqd" Light If Equipped after maintenance at every 5,000 miles.) - Replace Engine Coolant
- Replace Cabin Air Filter (If Equipped)
I don't disagree with your recommendations, but what you wrote may be confusing to some. There is a serpentine belt(accessory belt) and there is a timing belt(drive belt). There is no such thing as a serpentine timing belt.
The reason people do water pump at the same time as timing belt service is because you have to remove a ton of stuff to get to the timing belt - and water pump life is typically about the same as the timing belt and relatively cheap in parts cost. As you stated, the GS has a timing chain, so you can wait until signs of leak, and when it does, do yourself a favor and get the thermostat and tensioner done at the same time while you have the coolant out.
My 2003 Tundra 4.7 had a very serpentine timing belt.
https://en.wikipedia.org/wiki/Serpentine_belt
http://www.napaautopro.com/en/car-ma...rpentine-belt/
https://www.yourmechanic.com/article...ts-in-your-car
GibbsLexus
08-09-17 07:18 AM
