Brake Hold Retrofit
#31
So I looked through CarMax and CarGuru and some other sites for 2013 to 2015 GS350s. Not a single one had a Brake Hold option. It seems 2013+ GS450h and 2016+ GS350 have Brake Hold, the earlier years do not. This turned into a major retrofit project, might not even be worth the headache. If someone has a GS350 that has the brake hold feature, please message me!
#32
I can't find any associated parts for the Brake Hold feature to see how it actually works with all the safety lockouts, etc. I was hoping to find a layout or parts list. I tried looking at different car brands - M-B, Infiniti, Jaguar, Land Rover, etc. Nothing...
#34
I wonder if there is a difference between the brake actuator assembly for the vehicles that have Brake Hold versus the vehicles that do not have the Brake Hold feature?
#36
#37
Both have part numbers starting with 44050-30XXX, unfortunately it does not really describe anything in detail. I feel like I am overlooking something simple.
#39
Do MY13-15 GS have auto hill hold where it holds the brakes for a second or two to give you time to move from brake to gas without rolling backward? (Without having to press the brake all the way down to the floor first)
Does the GS450h in this thread that has brake hold also have DRCC? I'm wondering if it's the brake actuator (not sure if this is the right term) that's different? Thinking simply, don't non-DRCC cars not have the necessary parts for the vehicle to control braking on its own whereas DRCC equipped cars would have to be able to control braking function completely without physical pedal input? I wonder if there's a connection...
#40
In my '18, the pedal feel and response changes. For example, in Eco mode the pedal is soft, spongey and requires more travel whereas in Sport+ it's very firm and requires little input for strong braking. On the G-Force display in the instrument cluster, you also get a chart that shows brake and accelerator pedal position. Gas pedal is obviously electronic, but the brake pedal is also being electronically measured in the same way.
If this info can be of any use in helping you figure out what will get this working, the brake hold function has a bit of logic built-in and isn't just 100% on or 100% off. I'm pretty sure whatever pressure you put on the brake pedal when it activates is how much pressure the system holds the brakes with. It also pays attention to whether or not the vehicle is on a hill. When facing downwards on a steep hill and you press the gas to release the brakes and begin accelerating, it releases brake pressure slowly rather than all at once so you takeoff smoothly and gently rather than suddenly jerking forward.
#41
#42
Can't find anything in TS...what's interesting is that the software contains ECUs which don't exist in my car...I would have expected to find something about brake hold if it had been available. There was nothing for adjusting the hill hold time either. I'm keen to discover what actually controls the timing.
#43
44050-30A50 - This is for my car but with "pre-collision".
44050-30540 / 44050-30760 - This is for a 2013 GS450h that comes standard with the brake hold without pre-collision. This is the same as my part number... so I am assuming the pin is there for the brake hold.
I'm very reluctant to play around with the brake lines going to the actuator unless I'm 100% sure the swap will allow me to add the brake hold control signal. Even going from one production range to another or one year to another, the pin outs change dramatically. Wish I had more detailed wiring diagrams for the different 44050 part numbers.
#44
[QUOTE=eddie420;10372368]44050-30760 - This is the brake actuator assembly/modulator valve in my car that has no brake hold.
#45
[QUOTE=samsonn25;10848929]
Your message did not come through!
