View Poll Results: Would you like more of these kind of how-to posts?
Yes
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
117
100.00%
No
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
0%
Voters: 117. You may not vote on this poll
[HOW-TO] Dash Disassembly
#46
But you're still the man!
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/118x72/1_udaman_2ed18331438270e790851a1a941d74f3d38882bf.gif)
#48
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/600x315/look_everyone_087667a0b51af4e21f7469c9a5c8238fd4a3f64d.jpg)
#49
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20200423_215607_1f51a09e11cf0e95df8b40c8de6d5a805a9b2048.jpg)
I know that this is an old post, but I'm having a difficult time removing this trim piece. There seems to be a lot of resistance where it meets the center console. When I try pulling it a little harder, it makes the center console pieces bulge out as if the trim is connected to the center console pieces. Any recommendations? Thanks
#50
![](https://cimg6.ibsrv.net/gimg/www.clublexus.com-vbulletin/1128x1504/image_f153f5bcfb108964a32df3e8885ff0f06edc563e.png)
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/1244x804/image_d1255a25f9a2b4d6ef21e67c4b7c96d6c1c6e596.png)
Im2bz2p345 (04-25-20)
#51
Thanks! This was really helpful. I was able to remove all of the trim pieces tonight.
#52
How much harder would it be if I left the steering wheel on? I guess I would need to tilt the dashboard just to go over the wheel.
#55
I found a dashboard on ebay in great condition for the same price as a repair. I may bite the bullet and do this myself.
#56
This guide is a lifesaver! Thank you.
I made some notes along the way. I left the dashboard speaker in since I did not have a low profile 10mm socket or wrench. What I did was move the dashboard out a bit to where I can fit a 10mm socket.
I think you said you did not have to remove the center console. I was going off by memory so I apologize if I misread. It has to be removed.
You don't have to remove the steering wheel. I was able to pivot the dashboard over the column and take the whole dashboard out from the passenger side.
I thought the job would be hard but it was pretty easy. It's just time-consuming. I'm surprised that a lot of things are held on with clips. Down the road and with age, I'm pretty sure this will be a rattlebox.
eddie420 (10-13-20)
#57
I want to replace the instrument cluster screen b/c it has hard water or other spots that I've been unable to remove that are very annoying in the right light. I even used some plastic polish on a small masked off area to no avail. It's only about $40.00 so I'd much prefer to get a new one.
I'm wondering how much of this I have to remove to get the instrument cluster trim off. Does the stereo and ac trim, clock etc have to come off first? Can that arched instrument trim and the trim above the steering wheel come off with the steering wheel receded or is that why it was recommended to turn of the autoaway function? Does the small piece of wood trim piece below the driver vent have to come off as well?
#58
Also, if the steering wheel has to be out can the neg battery terminal be disconnected when the steering wheel is out and will it stay out or retreat when it loses power?
However, now that I'm thinking about this I don't really need to get to any electrical connections and disconnect them so maybe this could be done with the power on or even just buckling the seatbelt so the steering wheel is all the way out.
Any help would be much appreciated.
#59
I think it's illustrated on the first post.
Pull the meter garnish towards you.
Pull the trim around the steering wheel towards you and disconnect the connectors.
Remove the two top and two bottom screws from the meter, disconnect the wire clamp, disconnect the connectors, and remove the meter.
#60
