View Poll Results: Would you like more of these kind of how-to posts?
Yes
117
100.00%
No
0%
Voters: 117. You may not vote on this poll
[HOW-TO] Dash Disassembly
#62
#63
Interesting. I've been trying to locate photos of where it does but cannot seem to find it. So in that case, can that piece be disassembled from the rest of the dash? Reason I ask is because that piece on the GS F unique only to it. If the passenger bag does not blow through that piece, then I could just source a regular GS 350 dashboard I believe. Only difference between the two should be the top where's no suede on a standard GS right?
#64
The deployment cut out for the airbag is about an inch or 2 above the "SRS AIRBAG" text. If you shine a light at the right angle, you can see the deployment lines.
#65
I'm not 100% on the GS F and the regular GS. I do know that you can disassembled the top dash pad. You may need to find a dashboard that has the HUD cutout if the GS-F is equipped with a HUD.
#66
Ok I found a photo of exactly where it pops. Right next to the passenger air vent. Not on the top of the dash like I originally thought. So if that top piece can be removed(I assume it can be since it is sold seperatly), then I can just use a standard GS 350 dash since I don't see any differences other than the mouse fur on top.
Any GS top panel will work just get the one for hud or without or trace and cut the opening yourself if it applies.
#67
The top panel can be removed, but you have to remove the entire dash to remove it. The reason for this entire thread was the OP changed the top panel on the dash for the HUD specific one, related to the HUD retrofit. I avoided all that work doing the same mod by cutting the hole in the dash myself with a dremel/extention.
#68
Help and Advice Needed w/ Removing Plastic Interior Screw
Hello: I have a ‘16 Lexus GS350 with the “Type B” 12-inch navigation unit.
I’m trying to remove the plastic trim that holds the Nav screen in place to install some aftermarket cables.
That plastic trim is held in place by three plastic screws.
Two of the screw came out without issue but one screw — the middle one — won’t come out no matter how hard I try with a shorty phillips screw driver.
The screw spins separate from the plastic round that holds it in, but won’t come out.
I’m at my wits end but I would strongly prefer not to break the screw off by brute force.
Any advice and suggestion on how to get past this obstacle would be greatly appreciated.
Photos: https://imgur.com/a/I7PoUHF/
#69
#70
AJLex19 (08-18-22)
#72
Is anyone here to address a rattle? I’m having the one that sounds like behind the glovebox but can’t locate what, if anyone has a clue please share. Sounds like a broken metal pinch weld noise. It’s a body roll influenced 1-click ticking noise but can do multiple ticks as well.
#74
It's seems to be a common issue on the earlier GS. I did a fix once, but the crack will just expand. I ended up replacing the dashboard.
#75
Hi eddie420,
Could you please advise why we need to disable''Autoaway/Return function" i have plan to replace my GS350 2015 dash and also if i buy tis subsciption can i disable it by myself?
Thanks in advance.
Thanks in advance.
