3M Tape vs. Drilling holes for rear spoiler
Thanks for the suggestion, but what wheels are those on your GS they look amazing Im stuck between getting my stock 18in wheels powder coat or going with a new set of 19in wheels F-sport or other Lexus designs, just not a fan of aftermarket.
3M Adhesion promoter. It makes the surface better prepped for adhesion, but it will super amplify your adhesion and adhesion/initial cure occurs INSTANTLY. You only get one shot to line it up and stick it down. Once it's on, you cannot remove or adjust it. That's why I advise against it unless there is really only one way to fit the part you are sticking on. With a spoiler you will want the ability to adjust it in case you drop it down and it's slightly off. The double sided tape alone (VHB Automotive) will be more than enough to keep the spoiler on.
Twizgs (10-27-18)
I used 3M VHB clear. It's solid, won't come off without substantial effort if the surfaces are properly prepped w adhesion promoter.
But if you do need to remove it, it peels away nicely.
Twizgs (10-27-18)
Twizgs (10-27-18)
This is the same way to safely remove any emblems too.
sepukku
09-25-08 04:40 PM
dong888
01-17-07 10:32 AM
