Differential Fluid Recommendation
Old 04-09-20, 04:37 PM
Cwang
Cwang's Avatar
I use Redline 75w-90
Old 10-09-21, 12:26 PM
MOB561
MOB561's Avatar
Originally Posted by JeffKeryk
I am planning on servicing the differential on our 2013 GS350 F Sport that just hit 60K.
I do not want to use the Toyota factory fluid....
I am considering Mobil1 75w90 Synthetic LS or AMSOIL 75w90 Synthetic.
I believe 2 quarts should do the trick.
Any real world guidance?
Thanks in advance.
FYI, I will service the transmission with Idemitsu ATF; it's good stuff.
1.43 is what the Manuel says to use I purchased Amsoil 75w- 90 as well which was 39.99 and only has 1qt so now I guess I need to purchase another one just for the .43 lol
Old 10-12-21, 09:54 AM
AnirudhA
10th Gear
AnirudhA's Avatar
I used Royal Purple 75W-90 + a Cheaper off brand GL-5 equivalent for the .3-.4 litres that you need on top of the 1L, the manual says 75-85w (but it's. impossible to find and barely difference in viscosity between 85-90). The first diff fluid change will contain a lot of shavings, take your time and fish out the shavings from the holes using the magnet on the drain plug. Gl!
Old 10-12-21, 01:02 PM
Knucklebus
Knucklebus's Avatar
I used Mobil-1 75W-90. The difference between 75W-90 and 75W-85 will never be noticed.
I used it in both the front and rear diff on mine and 1,000 miles later, I can't tell any difference. Also, the old fluid wasn't bad but I got all the break-in metal off the drain plugs.
JeffKeryk (10-12-21)
Old 10-12-21, 03:00 PM
jonathancl
jonathancl's Avatar
I recently hit 100k mi in my 2013 awd.
I figured front and rear diff fluids couldn’t hurt.
Rear fluid looked incredible: still transparent yellow, only a bit of thick gray paste at the magnet. That fluid could have gone another 50k miles easily.
Front fluid showed more age: darker amber, still quite transparent up close but much darker than the new fluid. Very thin paste at the magnet. Getting at the fill plug in the front is tricky, very hard to get back in with larger hands.
I used gl-5 75w85 for the rear and gl-5 85w90 for the front. Also ordered a set of transmission and diff replacement washers for like $6 on amazon, includes what you need to replace any of them.
Old 09-07-23, 12:04 PM
GS350awdbase
3rd Gear
GS350awdbase's Avatar
Originally Posted by bclexus
I'm guessing you think the Toyota/Lexus engineers don't know what they're doing...
While your non-Toyota lubrication choices for the differential should be fine, I'd be very wary of using anything other than Toyota WS automatic transmission fluid in the transmission. Transmissions cans be very finicky about even a slight change in the fluid used...and Toyota transmissions are no exception.
Toyota/Lexus engineers do not create the transmission fluid used in their vehicles. They just tell the people who make it (Aisin makes the Lexus ATF) what specifications it needs. Amsoil is 100% superior to their products as it is 100% synthetic and has more additives that allow it to last for longer intervals and work better under extreme temperatures. I drained and filled my Lexus GS350 with Amsoil Signature ATF and it's running buttery smooth. Plan to do it a third time at 60k miles to have it mostly Amsoil ATF in there. Already put in about 2k miles with the Amsoil and no problems.
JeffKeryk (09-08-23)
Old 09-07-23, 02:14 PM
charley95
charley95's Avatar
As I stated back in 2020, here we go again.
Stemmer
RX - 1st Gen (1999-2003)
13
11-20-21 09:55 PM
RX3302004
10-25-15 07:21 PM
Oilguy
09-11-13 02:27 PM
driver321
02-25-09 12:01 PM
Paul B
04-18-07 09:36 PM
Quick Reply: Differential Fluid Recommendation
