Differential Fluid Recommendation
I am planning on servicing the differential on our 2013 GS350 F Sport that just hit 60K.
I do not want to use the Toyota factory fluid....
I am considering Mobil1 75w90 Synthetic LS or AMSOIL 75w90 Synthetic.
I believe 2 quarts should do the trick.
Any real world guidance?
Thanks in advance.
FYI, I will service the transmission with Idemitsu ATF; it's good stuff.
Thanks in advance.
My mechanic used 75w-90 Mobil 1 synthetic GL-5 gear oil for the rear. Here's a great DIY from one of our forum members: https://www.clublexus.com/forums/gs-...id-change.html
Thanks in advance.
Thanks in advance.
While your non-Toyota lubrication choices for the differential should be fine, I'd be very wary of using anything other than Toyota WS automatic transmission fluid in the transmission. Transmissions cans be very finicky about even a slight change in the fluid used...and Toyota transmissions are no exception.
Measured (04-09-20)
I'm guessing you think the Toyota/Lexus engineers don't know what they're doing...
Thanks in advance.
Thanks in advance.
There is nothing wrong with the factory fluids.
I don't know much about the differential fluid, except it is kinda pricey.
Mobil1 75w90 LS is synthetic and is about $15 a quart. This is what I will probably use.
WS ATF is not synthetic; Idemitsu has a WS replacement that is synthetic.
They worked with Toyota to develop the blend.
https://www.idemitsulubricants.com/i...tf/type-tls-lv
Personally, I do not believe in lifetime fluids, but that's just me.
We also have a 2006 Acura TSX with 185K miles; a wonderful car.
I serviced it regularly with Honda DW-1 (synthetic) since new.
Last time I used the Idemitsu equivalent and the transmission was simply wonderful.
Dang thing pulled better off the line better; was better all around.
Finally, this thread was not about dissing Toyota fluids.
I specifically asked for real world use of differential fluids other than factory 75w85 fluid.
Thanks to all who posted.
So, I do not believe there is anything wrong with the factory fluids.
I do believe there are better fluids out there.
+1 for factory fluids, they are well designed for their purpose, though gear oil difference will be negligible if you use aftermarket.
i'm also under the opinion to only use Toyota ATF in the transmission, as pointed out they are very sensitive and specific to fluid types.
this has always been the case with older lexus cars and more so with the newer!
For me the ATF is definitely one of those things that fall into the ain't-broke-don't-fix category. Chances are the transmission would work just as fine with other fluids, but I don't see the point of taking the risk unless there's a clear upside.
It's just too complicated a matter for most people to understand correctly. Unless I work at Toyota/Lexus as a ATF tester and know for sure there's an better alternative that's not used because of cost, I wouldn't deviate from the factory recommendation. The factory fluid should be the right compromise among performance, longevity, noise, and cost for most people.
14GS350 (09-10-23)
The answer was - Mobil 1 is making for us 75W90, despite the owners manual recommends 75W85
14GS350 (09-10-23)
I ended up with Redline 75w85.
