Need help with rain-sensing(AUTO) wipers
I need help from those of you with Rain-sensing(AUTO) wipers. I want to know how your AUTO wipers operate so that I can confirm if my wiper function (2013 GS350) is working properly. My issue is that I can't get the wipers to work in a manual, intermittent mode, with frequency controlled by the interval adjuster. I have read, and re-read the manual, and it seems that the wiper controls do not work like the manual states. If you could answer the following questions, I would greatly appreciate it.
- Can you use the wipers in a manual (AUTO off) intermittent function, and change the frequency with the interval adjuster?
- If so, how do you get to manual with intermittent function?
- Can you turn AUTO on/off with a single push of the AUTO mode on/off switch? (It is supposed to require holding AUTO on/off switch until flashing stops. Mine will switch with a single push. Most times it won't change if held until the light stops flashing, but sometimes it will.)
- Is there a minimum time you must pull the lever for washer/wiper operation to get the wiper to move? (I can briefly pull the lever and get washer, but if I release too soon the wiper will not operate)
I always just leave mine in AUTO, so I wasn't sure about your questions. I just went out and played with it and this is what I found:
Yes, I can go into a full manual mode, with the intermittent mode (with variable control), low, and high.
I first pushed the AUTO button once, so the green light went off. Then I held down the AUTO button for several seconds. It flashed, then extinguished, and from that point I was in full manual mode.
No. Simply giving one momentary press of the AUTO button didn't disable AUTO. It did turn off the light, but still didn't go into manual mode.
I didn't count how long I held it down, but not long. Just a deliberate motion, maybe 1 second or so.
I hope this helps.
I hope this helps.
The following 2 users liked this post by JDR76:
swscott530 (11-22-18),
theplotthi (10-26-20)
You'll need to read your Owners Manual (Pages 198 thru 204) to fully understand the operation of the wipers. It's next to impossible to explain the various operations on a forum, and the manual does the best job in my opinion...however, I'll grant you that the Owners Manual explanation is difficult to comprehend on the first or second pass.
The right side stalk can be moved up and down to five (5) different positions. The functions are marked on the
barrel of the stalk. Uppermost position is momentary only (will not stay here) labeled "Mist" and is to engage the wipers once.
Second lower position is "Off", suitable for car washes. Third lower position is "Auto" and has the lever positioned flat, horizontal, straight across.
This is the normal operation position for most driving. The GS is exceptional among all Lexi in offering the tip of the stalk "Auto" button. (All others
do not offer the plain "intermittent" control). With "Auto" turned off (no light) the revolving barrel switch can be turn up for more wiping and down
for fewer strokes just like other cars. When you tap the "Auto" button and the light is on you have transferred control to the sensor that is up
by the inside rear view mirror. When is rains a little, it wipes a little...when it rains hard, the wipers wipe hard! Now the revolving barrel is your
input into how sensitive do you want the initial start up to be? My wife likes an early response to any (ANY!) drops on the windshield, me...less.
The two lower positions (below horizontal) are just regular low and high speed manually controlled wipers.
theplotthi (04-12-21)
Thank you, JDR76. That helps a lot. I was confused with the meaning of the AUTO indicator light. I assumed that when the AUTO light was off, then AUTO was off and it was in manual...that would be too logical (mcomer's explanation helped). Now knowing that it is a two step process (one push to turn off AUTO light, then hold until AUTO light stops flashing) to get to manual, intermittent I have got it to work. To me it shouldn't be that complicated, but I'm glad to know it wasn't problem with the car (just my lack of intelligence...I read the manual, but was never able to figure it out). Thanks, again.
I'm with you mcomer, I like minimal wiper use...so it was frustrating when I couldn't reduce the frequency during a sprinkle or light snow.
chrisfan
IS F (2008-2014)
19
10-11-13 07:35 PM
