Please help!!! 2014 GS 350 clock running too fast!!
I don't think it is a common problem at all. But, you'll need a new clock.
It appears the clock's related circuitry is in a sealed case mounted directly behind the clock face. I don't know how difficult it may be to get into the case in order to test/repair/replace component(s) if you were so inclined, but it looks like the black part directly behind the clock bezel just unclips which likely gives access to the crystal oscillator and other related circuitry. I seriously doubt there is an adjustment that can be tweaked...
I looks like a new Lexus Clock P/N#83910-30620 is in the low $200 range for just the part. I suspect it would cost a minimum of a few hundred dollars if Lexus replaced it for you...
The following 3 users liked this post by eddie420:
You could look for a wrecked GS. Good thing is all models have this clock; I don't know it if need to be "paired" to the car however. I would research that. It most likely does not.
Sandy72 (07-09-21)
When you say your clock is 30-40 minutes ahead everyday, do you mean you correct the time on it and in less than 24 hours it’ll be off by that much again?
kperry1911 (10-12-23)
im experiencing this same issue. Every morning since daylights savings tie, my clock is at least 40mins off when i get in the vehicle in the morning. II set the clock to the correct time and 8hrs later it begins moving ahead again.
Also curious if you don't set it each day, does it just keep adding 30-40 minutes every day, or is this a 1 time thing?
Any new info on this ?
Anyone had their stock center dash analog clock run a bit too fast on their GS350?? Each morning when I get out my clock is at least 5 minutes fast. If I let it go it will progressively increase to be more and more off the current time. Any ideas what the hell is happening here? Thanks.
Thanks in advnace
Clock running slow/fast
