2015 GS-350 F-Sport with ML Underwhelming
What's going on guys!
Just got myself a 4th Gen GS with the Mark Levinson Audio package and I'm quite underwhelmed. Even my old 06 Maxima's Bose system was better. I'm coming from an F10 with a base package and it blew this thing out of the water. I absolutely love everything else about the car but I'm looking to swap out the audio so I was looking for suggestions or things that may have worked for you all who may have done similarly.
I'm willing to spend some bank but obviously if there are any non-bank-breaking alternatives, I'd love your suggestions! I already have a JL 500 mono amp that I'm going to install with a 12 inch ported sub, but I was looking to see if there was anything I could do about the Highs and Mids to make it sound better. I've perused through the forum looking for advice but haven't made any ground.
Any input is greatly appreciated.
MOB561 (09-02-20)
Step one is to turn off surround sound, if you haven't already.
I tried the ML in a GS350 equipped with it and I was not very impressed either, after listening to it and comparing it to a non ML it was not any kind of priority if a GS had it, the non ML has the capability to play DVD's too so it did not matter to me. ML sounds much better in a LS compared to a non ML LS though. I don't think you will notice much of a difference especially if you mainly listen to the radio/satellite.
I’m very happy with the ML in my GS and I’d pay for it all over again. My 2014 IS had the base system and I really regretted not getting ML in that.
The following 4 users liked this post by JDR76:
I prefer a more dynamic sound and find the ML to be weak with the bass. However, the ML is tuned to be closer to an audiophile's liking, reproducing the sound more naturally as intended, with much of the sound staged at the front of the driver.
Check out this thread ML thread
... and these settings:
signdetres (12-11-18)
I guess it all depends on the type of music you are trying to listen to. If you're doing R&B, rap, or any jams with a lot of bass then yes, this car will have the wrong audio system for you.
The following 2 users liked this post by azipod:
jonathancl (12-12-18),
MOB561 (07-08-20)
This thing helped... a LOT.... Occasionally they go on sale for $140. My iPhone 7 sounds like hot garbage compared to this....
https://www.amazon.com/Sony-NW-A45-Walkman-Hi-Res-Grayish/dp/B0765ZVM6Y/ref=sr_1_3?ie=UTF8&qid=1544587786&sr=8-3&keywords=nw-a45
Install a DSP it will solve the issue and you may not need additional subs. I have a JBL MS8 installed, it gives me complete control over the factory sub which hits harder than you would think. A DSP will also address bass roll off and allow you to utilize the full potential of the cars speakers. Many months later I ended up adding two 12's from a previous setup but that's because I've added sub's to every car I've owned. Most people will happy with a MS8 since you have control of the factory sub, if not its very easy to add subs at a later date.
Yup. I have these settings now and it only makes it bearable. I agree that the ML system beats out most stock systems, but even the mids and highs are nothing compared to what was originally in my BMW. Even the ML system in my brother's LS sounds better. I'm not trying to knock anyone's opinion on the system or act all high and mighty, but I work as a concert photographer and I cant bring myself to agree with the statement that the ML system in this car is meant for audiophiles who don't focus on bass. Not even classical, vocal, or choral music sounds good in my opinion. I think the issue here is that the ML package probably has great sound processing, but uses crappy speakers.
I'm going to try replacing the two front door speakers and adding a 12 inch JL Ported sub and seeing how that sounds. Only issue is that my sound guy showed me two sets of speakers that cost over $700 which I think is unnecessary. Any good 6.5 inch speakers you guys recommend? I don't MIND spending the money if its the best option but I'm fairly confident there are much cheaper quality options considering the ones Crutchfield recommends are $40 and have amazing reviews.
Thanks for the info everyone!
The stock m/l does sound like it's badly eq'ed
Can you show how you routed/hooked up everything/explain the whole process ? I was thinking about doing this but you are the only one I seen who actually used the MS8 with ML. Would you say it addresses the crazy rumble/farting with the deep low bass?
I can’t myself understand how a factory ML sub can pop or sound so muddy with certain songs when factory. Hoping to just fix that with the MS8 and improve clarity etc. Any help would be awesome. Also your settings for the MS8 would be amazing, and what genre’s you listen to. Thank you !
sheriffwoo
10-17-16 06:37 PM
roosta23
06-12-14 10:52 AM
