GS strut leaks?
How prevalent are GS strut leaks? I found some threads on Club Lexus about people's struts leaking after very short period of time and the replacements leaking as well. Most recent one on the front page of Suspension subforum. https://www.clublexus.com/forums/sus...ve-struts.html
And it seems like quality 3rd party struts are lacking, probably due to low sales volume of GS. Should a potential buyer think twice over this issue?
But if you keep your suspension stock and run the 18 inch rims you shouldn't have to ever worry about your strut leaking for the life of the car, unless you consistently hit some really serious potholes. I've hit a few bad potholes, but never had a bent rim or suspension problem.
2013 Lux. Purchased in 2017 w 72k miles.
Replaced springs w Tanabes May 2018, observed no issues with any shock, will be a good case to monitor over the next few years.
The shocks are about $200/piece. It's not the end of the world if you have to replace them. I think Lexus has updated the part #s on the original shocks... not sure if this is due to an improved design or because of something else.
Unfortunately, I think it's more prevalent than your average reliable Japanese make. It's actually quite shocking to me. When I was shopping for a GS, I came across a number of used ones with service histories showing that the shocks were leaking and failed way before the warranty expired.
I was looking primarily base only, then just recently switched to looking at F-sport and found this issue. Just trying to compare notes.
The adjustable suspension on the f-Sport might still have a stiffer setup than the base 450h in all modes.
The F-Sport, Hybrid, and Luxury all have the exact same shocks (all same part numbers). The only difference with the F-Sport is that the electronic ride control model is tuned more aggressively only in the S+ setting. These are the models that seem to have leaking shocks.
Not sure about the base models. The base models do not have the AVS and uses non-adjustable shocks.
Lowering springs seem to add to the likelihood of failure.
I noticed wetness at the tops of both rear shocks and a little on the LF, like they were leaking. Dealer said its "normal for a little wetness to appear" and did nothing. Car still drives fine, but I only have 18k right now.
My 2013 GS350 F-Sport RWD blew a front shock at two years, 13,000 miles, repaired under warranty.
