Quick Dashcam Question
Hey folks I have a question regarding hardwire install of a dashcam. Just installed the Rexing V1 and it came with this hardwire kit.
I plugged it into the Front Charging port fuse under the passenger side dash. I only want the dashcam to power on when I turn the car on and power off when I turn it off. My question I guess is the front charge port in the center console always hot? As it seems the dashcam stayes powered on even when I shut the car off. If this is the case can someone point me to a 15A fuse that is only hot when the car is on? Thanks in advance and I did search but am not coming up with any results. Apologies if this is a dumb question.
The battery in the unit is for graceful shutdown, not to continuously power it. Be careful if you live in a very hot region. The battery can leak or explode. Units with capacitors are better for those regions.
maclem8223 (12-23-18)
Edit: Looks like the ACC is 7.5A and the hardwire kit is a 15A
The following 2 users liked this post by maclem8223:
eddie420 (12-23-18),
jonathancl (12-23-18)
Edit: Someone please correct me if I'm wrong on this being the heated steering wheel fuse. All I know is it is 'hot on start' and not always on which is what I was looking for.
my problem is im looking for one thats 20A or blank thats only hot when on. I have yet to figure it out for the passenger box. I have found it in the trunk but haven't found a good place to stash the battery and thread the wire to the cabin.
