My Orginial spark plugs at 85k
#46
listen I've been a mechanic for too long and I have pulled thousands of plugs and the iridium plug would last forever. Now for people running boost or No2 change them when YOU feel, but for daily use every 60000miles is fine every iridium plug I have replaced " could go back in "they are that tuff, and no you don't get anymore performance, unless there is something wrong with you car to start with cheers.
If I'm not showing any problems with how it's running, engine codes or fuel consumption thinking I'll just wait a while and change them at 80-100k miles.
#48
I've got about 68k miles on my recently bought GS350. No record of the plugs being changed at 60k. Is there any reason to rush to change them? As I said in a previous post, I've also got a V6 Camry which has a 120k mile change interval and that's quite a difference for a very closely related engine. Is the direct injection a factor in recommending an 60k vs 120k change or maybe they think Lexus owners will be more willing to shell out or maybe the fact that the Camry rear bank is so much harder?
#49
Replacing the spark plugs at 60,000 miles is 'Required under the terms of the Emission Control Warranty'. Therefore, if you are not concerned with voiding the Emission Control Warranty, then there is no need to replace the spark plugs. Iridium spark plugs will be as good as brand spanking new when they have 120,000 miles...and will almost certainly be as good as new at 180,000 miles.
