High Negative Camber on Rear Wheels?
Old 01-09-19, 11:38 AM
Knucklebus
Knucklebus's Avatar
Originally Posted by TOPENDMS
I would suggest everyone get the alignment specs from the Lexus Manual and not to use the alignment rack specs. It will give you a better toe angle to reduce inside wear.
The front Lower control Arm Bushing I would replace with firmer Lexus GSF.
Keep your tires at optimum tire pressure, do not over inflate.
I would not get a camber kit.
Visually you will see negative camber on Lexus from factory, it is standard.
The absolute best tire wear and gas mileage comes from tires that roll straight ahead and vertical. We have a smidge of toe because the bushings give a bit and the tires straighten out under way. Camber is only good in a turn and that should be provided by the suspension. Compression on the outside tires and positive caster for the front should provide camber gain in a curve.
bigl93
Suspension
09-27-15 09:57 PM
kevinly89
CT 200h Model (2011-2017)
05-02-15 12:10 AM
menty
Suspension and Brakes
09-06-09 06:19 PM
nihard
09-26-08 05:19 PM
Quick Reply: High Negative Camber on Rear Wheels?
