Fourth Generation Lexus GS 350 Rear Axle Hub Replacement
#46
The open part of the dust cover was crushed on the edge and the Speed Sensor ended up bent inward. Your writeup is solid. Just wanted to point out this one issue.
#47
Have any of the pictures posted in this thread shown the area? I am still having difficulty seeing how it happened. I was more worried about the wire getting broken as it is very thin and mounts on the upper control arm.
#48
Now I have a 3rd and 4th Gen GS350 but I cannot tell you if the rear hub setup is the same. However, it sure looks like it and this is exactly what happened to me:
Something to avoid when replacing rear wheel bearing - ClubLexus - Lexus Forum Discussion
#49
But then again, I've been working on cars for over 40 years and motorcycles/minibikes/bicycles/lawnmowers for almost 50 years so I tend to be aware of my surroundings when working on things. I break fewer and fewer things these days.
Current project:
Buick 350 (5.7L) 92,000 mile timing chain.
92K sludge in Buick oil pan.
Buick 350, original 1971 engine and Munice 4-speed. Exhaust manifold bolts came out without breaking a single one!
spineman (06-13-22)
#50
Back at it today trying to resolve the problem. Now I know what happened. The dust shield was not seated properly and spun, cutting off the bottom of the sensor. Not sure just how I'm going to get out of this. It appears the axle has to come out of the hub, which looks like the knuckle needs to come off. Good grief.
Knucklebus (03-26-21)
#51
I bought my $300 speed sensor and read how to run the wires up to the back of the back seat. I also bought a new dust cover because I want to do it right and I really mangled the old one. Question, please. Can't find info on it. For the rears on 4th Gen, Is the tone ring internal in the hub or attached to the axle? I'm waiting on parts so I have not taken it back apart yet. Wish to hell the sensor was attached like the fronts $$$ ouch. Thanks.
#52
At any rate, it looks like I get to do this again. I got 11,000 miles out and 2.5 years out of my cheapo bearing. I was rereading this to refresh on the part number for the 32mm nut if I need a new one and the tools I need to borrow.
I'm buying one from a Lexus Dealer out of Scottsdale, AZ. Hopefully, it is better than the last two, including the first Lexus one.
#53
OK, here we go again with OEM parts.
New parts unboxed
New parts
New parts unboxed
New parts
#54
Well, that was a cluster. I've killed my car!
I think I've already ruined the new bearing, crumpled the dust shield and likely killed my ABS sensor.
Carnage! Anyone know the best way to get the dust shield out? Is it removal of the rear hub or can I get by with simply removing the upper control arms and slide it out? I don't know if the bearing can be reused but the dust shield has got to be replaced.
Anyone know how to verify an ABS sensor good or bad? It is intact.
Wrinkled dust shield
Rear of bearing rubbed off.
adict2rice (08-13-22)
#55
Well, update. I had to remove the entire steering knuckle, which was a bit of a chore. Also, the dust shield is pressed on. Hmm, at a standstill until I can get to a machine shop tomorrow. As a matter of fact, the book details removing the entire knuckle to install a new bearing.
So, that answers the age old question: I was lucky when I replaced the last bearing.
Frankly, I think it is an overly complex design, possibly even a poor design.
Pictures of the back side of the knuckle, the new and old dust shield.
Dust shield, sticking up too far.
New dust shield and old dust shield. Clearly, the old dust shield was pressed on.
Im2bz2p345 (12-01-21)
The following 2 users liked this post by charley95:
Im2bz2p345 (12-01-21),
Knucklebus (11-28-21)
#57
The car has been down for over a week now and I've had to borrow my wife's car when the weather is bad or drive my other GS, the 51 year old one. I'll get it back together one way or another.
#58
I just replaced both driver side hubs, front and back, on my RCF... and the front, the car being RWD, was a breeze... the rear, not so much 😑 I did go with OEM parts since I don't trust the quality of all these aftermarket parts made in China, especially when I'm putting it on a nice expensive car. Cost me a pretty penny but well worth it.
#59
Did you do it yourself? There is no way to put the dust shield on the bearing hub without some kind of press and a mandrel designed for the job. My buddy's bearing press kit doesn't have any that will do the job.
I'm going to call a machine shop to see if they think they can press it on. If not, I guess I take it to Lexus to see if they can do it for me. I need to get my car back on the road.
#60
Everything going back on my car this time is all OEM Lexus, likely still manufactured in China though. The bearing before this one was Lexus too but it ate the dust shield and broke the ABS sensor.
