2015 GS 350 New owner heater question
I recently replaced my 2007 GS 350 with a 2015 GS 350. Getting used to the differences (already really miss my touchscreen) but I noticed my 2015 heater does not blow very strong (tried all the venting alternatives)and takes much longer to heat, is this typical? I have one of the versions of the “cold weather package” with deicer, water repellent windows and “high intensity heater” (noticed stickers on some other Lexus say “heavy duty heater” not sure if there is a difference?). Anyone else have this concern? Thanks much.
What's the outside ambient air temp?
Try pressing the "AUTO" button as well as the auto recirculation mode button to put it in fully automatic mode and then set the temperature to "HI" for both sides and see if this gets the cabin up to temp quicker. It'll direct air to the windshield and the floor while it heats up so it doesn't blast you with cold air.
Has the cabin air filter been replaced recently?
I would also ensure you're not in the Eco driving mode and if you go into your climate control menu, also ensure through here that Eco climate settings are not enabled.
Although I live in Los Angeles and we don't see the temps you might be used to seeing in MA, regardless, my GS has had the quickest heating system (from climate control system, to heated seats & heated steering wheel) out of any of our previous cars.
I used to have '11 GS350 AWD and I don't feel like the heater takes any longer to heat in my '15. We often go below 30degrees F here and sometime single digit(like 2 days ago) and I'm not afraid that any of my vehicles not having adequate heat.
However, I do feel the '15 AC is not as cool as my '11 was. I mentioned it in one of my service at the dealer and they said to crank it up.
Appreciate the quick reply! I had tried some of your suggestions (eco off and auto) but will look further, especially about the filter. It was a CPO vehicle that just had a 30K service but I shouldn’t assume filter replaced. It has been single digits here some days but had noticed issue previously at higher temps, even though I’m not cold sensitive and rarely crank the heat. The cold weather pack gave me higher expectations but it is not even as good as my wife’s Camry.
I leave my heat set between 70-72. System is on full auto. Car is not in eco mode. I feel like it heats up at a normal speed, probably faster than the past two cars I've owned. I have noticed that it won't shoot much air out of the dash vents until the air is actually warmed up. Someone else in the thread said the air comes out the defroster vents and foot vents until it is warm, so that you don't have cold air blowing on you, that seems accurate based on my experience. Maybe that is why you are getting weak air?
Also, I use the S-Flow setting. That is supposed to heat only the area where there are occupants. I believe in my car (luxury package) there are occupancy sensors for driver and passenger. If I have people in the back seat I need to manually disable S-Flow. I am not sure if non-lux package cars have a passenger occupancy sensor, I think they may not.
When that happens, is it also disabling the passenger side air vents? Or?
When enabled, if the passenger seat heater/cooler was previously left on, when I start the car, I see it turn on for a second but then automatically turns off when it realizes there is no passenger. It does not, however, turn off the passenger side temp control like I think happens in yours, but frankly I don't really know what that actually does on the more advanced versions.
