GROM VL2 installed
#721
Did anyone know if you press the check for updates button in VLINE settings it puts you into beta tester mode? You can then install beta firmwares & updates.. Not sure if i trust it however.
On a side note 2 questions for anyone who can help
1) Where is this announcement about Wireless Carplay? Does it say which Vline supports it ? I have a V8 Vline
2) What's the diff with V7/V8/V9 VLine units ?
--- Asked grom this they said 7/8/9 are same hardware - Just different cables
Thanks!!
Thanks!!
#722
I have some issues with my VL2 but Grom Audio is aware of these issues and they are working on a fix. However, yesterday morning I asked Dmitry @ Grom Audio if it was OK to install the Beta firmware and software that is available for LEX6 (I have 2012 CT200h) and he replied immediately asking me to revert back to Release channel as Beta channel is only for technical testers. If you install a Beta firmware or software without Grom Audio authorization and brick your unit, they are not responsible for any damage caused to the unit or to your vehicle.
They did confirm Wireless Carplay to me Mid-March. Wonder if its in the beta
#723
That is what I was told but I think they are focusing right now on fixing a few bugs before releasing Wireless CarPlay. Dmitry told me yesterday that the new firmware would be available yesterday late night but it's not available yet. I guess they didn't finish it or they found other bugs. Main issues for me are UI Shortcut is broken (according to Grom it's broken for the whole LEX6 platform) meaning I can't access to USB Audio settings, black screen after 10 mins of turning ON the car, factory bluetooth causing black screen when used and VLine not found after tuning ON the car happened twice already. Turning ignition OFF and ON fix this particular issue. Anybody would say, why not returning it? well the problem is that when CarPlay works, it is just amazing. Fortunately I'm still in the returning window but after experienced CarPlay, even with all these bugs, I don't now if I would be able to live without it. Also, GROM VLine is the only interface available for my 2012 Lexus CT200h so it's this or nothing.
#724
Genuinely curious about Android 10 + Wireless carplay tho ..
#725
PlPete, OUT, YaMomma, you guys have 2013-2014 GS right? This issue have never occur on my 2015. Must be something different with our radios. I know 2015 had some revisions to software. Well, hope GROM will fix it. Doesn't seems like a huge bug though and easy enough to work around.
#726
You shouldn't do anything your not comfortable with however it wouldn't surprise me if the beta version fixes your issues. Start small and only try the beta software i wouldn't mess with a beta firmware unless your comfortable using a boot loader and have a usb keyboard.
In regards to if wireless car play works on beta, i have no idea because i don't use car play. I refuse to limit myself on the apps i can use and the majority of my apps aren't on car play
#727
Installed the latest software in my VLine and UI Shortcut is still broken and now music sounds distorted, like a low resolution mp3. I plugged my iPhone on factory AUX input and it sounds fine. Grom did something in the new software that degraded the sound quality. If I don't get a solution tomorrow, I'm going to ask for a RMA and return this thing for good. I have dedicated already more time that I was planning. If all these glitches are the price to pay for having Apple CarPlay, then for me it's not worthy.
#728
My carlinkit has zero issues, then again it's not android based with buggy software.
#729
I'm out the country right now so I can't post pics but search for my posts under this thread. I posted a bunch of pics of the GROM video cable the one with DVI to two GVIF connectors. The DVI end was soldered wrong; I think the bought a GVIF cable, cut it in half and then soldered the DVI end by hand to make the video cable that connects the in car 12.3 display , the OEM head unit and the VL2 together.
I desoldered it and rebuilt the cable correctly, now I have no issues with flickering.
#730
So heres my short writeup:First, the shield is not connected on all the GVIF cables to the DP connector shell. Second, the soldering job is very poor and has solder bridges and solder over places where there is no connection. And third, GVIF requires 100 ohm STP coaxial cable, this is PVC 2 pair. You guys need to fix this, this is really unacceptable for a $600 unit.I have made cables for high speed Serial video before, if you can't find twinax 100 ohm cable use CAT7A; it will work fine if you can solder....
#731
Sorry but the only way to tell is to open up your cables and inspect them. I know when people say "this is common bug" that's a lie; its 2020, everyone has figured out how to make a video signal pass to a display without dropouts lol! So if GROM keeps saying oh this just happens they are probably lying if the video looks great and then just drops out.
P.S. The thread has a LOT of pictures so if you have find who has a solder station and can do some soldering they could at least inspect your cables, possibly fix them if they see an issue.....
#732
Here the link to my post with the pictures. This post and the ones after have the rework pictures if you need a guide:
https://www.clublexus.com/forums/gs-...l#post10489200
#733
https://www.amazon.com/SCOSCHE-Adapt...TFV2KB1BZM07YY
That's the link he sent me I'm guessing it connects to a loose wire in the back when installed.
#734
uhh I don't think so; im not so sure that cable will work, as I think its for Lexus cars that have a single USB port and not the dual USB/ AUX input our cars have.. if you buy keep the receipt if you need to return it and let use know. I personally just ran two USB3 cables from the VL2; I love the sound quality of the ML iPod integration too much to give it up.... I use CarPlay when I am with the wife and/or need nav, Siri and everything else...
ShadeXero (02-26-20)
#735
