GROM VL2 installed
Old 07-25-21, 09:34 AM
  #1066
ShadeXero
ShadeXero's Avatar
Originally Posted by itsraysgs
Does anyone know why “waiting CarPlay UI” takes forever? Sometimes it wouldn’t even connect and I have to “tap to connect” again.
My wife's iPhone has been doing this as well. Cord or no-cord. Most of the time it loads after a few minutes, then cuts out 3-4 times, then finally comes back.
Although, 50% of the time it doesn't work at all.
wannano (08-14-21)
Old 07-25-21, 10:39 AM
  #1067
HUSKERnKS
HUSKERnKS's Avatar
What version of iOS are you on?
Old 07-25-21, 05:34 PM
  #1068
ShadeXero
ShadeXero's Avatar
She's one back from the latest iOS 14 build.
I just tested with Wireless AA and it seems to be doing the same thing. Won't connect, probably needs a full reboot every time to make it work.
wannano (08-14-21)
Old 07-25-21, 06:01 PM
  #1069
HUSKERnKS
HUSKERnKS's Avatar
Let's both report it to GROM. I am seeing the same thing. The more of us that report it, the faster they will fix it.
The following 2 users liked this post by HUSKERnKS:
ShadeXero (07-25-21), wannano (08-14-21)
Old 07-25-21, 06:24 PM
  #1070
ShadeXero
ShadeXero's Avatar
Sounds good. I just made a ticket.
Edit:
Ugh, they're making me do all the basic steps. Update (already did), factory reset, etc. Be prepared to waste a bunch of time.
Old 07-25-21, 06:41 PM
  #1071
HUSKERnKS
HUSKERnKS's Avatar
Me too. We shall see.
ShadeXero (07-26-21)
Old 07-26-21, 10:18 AM
  #1072
jdpdata
jdpdata's Avatar
I'm seeing same issue in my RLX on WAA. GROM will fix it soon, I hope. Had to switch back to OEM navigation on the way home Saturday night.
Old 07-28-21, 06:26 AM
  #1073
mfaheem
mfaheem's Avatar
What's the consensus here for the early adopters ? Is grom vline 2 the best solution out there for android auto ?
Looking to do something with the infotainment system soon.
Old 07-30-21, 07:01 AM
  #1074
mfaheem
mfaheem's Avatar
Well, I ordered this and now looking into installation. Has anyone installed this in the armrest console ? Seems like the best spot without needed to drill anything. If you install there what did you do about the gps locator?
Old 07-30-21, 07:07 AM
  #1075
mfaheem
mfaheem's Avatar
Originally Posted by Whitfield
Bob - here is mine mounted under the pull out tray in the center console. Fits perfect and frees up space in the glove box (wife uses it to store grocery bags). The power cable was just long enough - I wish I had 2 more inches. Ran the wires down the right side of the center console. As Eddie said - there lots of room there.
This is just perfect and exactly what I want to do. Just a few questions before I do the same thing. What did you do about the gps receiver ? Where was that located?
Old 07-30-21, 07:54 AM
  #1076
mfaheem
mfaheem's Avatar
Originally Posted by jdpdata
Finish my install today...
Cut a small open in filter door to route harness. Didn't want to hack up my glove box, so this is more reasonable.
Mount VL2 with some automotive grade Velcro. Easy to remove if I need to access cabin filter.
Zip tied everything down for nice OEM look. Don't know what all these HDMI and VGA ports are for. Maybe future expansion..front cameras? Full Android Auto and Car Play are supported in the future with those USB ports.
Route GPS to passenger pillar. Looks very OEM.
How come your aux port is occupied ? I though the Grom uses the factory mic for the GS 350 ?
Old 07-30-21, 08:16 AM
  #1077
slvrcrz
slvrcrz's Avatar
damn i really wanted to update, so for those of you guys that have it, would you recommend it ? is there any issues that is going to be a deal breaker for you guys ?
Old 07-30-21, 08:28 AM
  #1078
mfaheem
mfaheem's Avatar
Originally Posted by eddie420
I wish I had a better picture to explain what I am talking about. If you remove the center trim behind the cupholders, there is a lot of space to route wires into the bottom compartment under the tray. To me that was dead space I was not going to use for anything. Frankly, you can mount it anywhere you see fit, but the center console has good depth to mount this or any similar dimension items down there. Sorry I can't explain this better.
Do you need to drill a hole for the cable to come inside the center console underneath the tray ?
Old 07-31-21, 11:07 AM
  #1079
eddie420
Forum Moderator
eddie420's Avatar
Yes, if you want the cable to come into the tray, you need to a drill a hole. Takes a few seconds, it's only plastic. Any drill will do the job fine.
Old 07-31-21, 11:17 AM
  #1080
jdpdata
jdpdata's Avatar
I'd highly recommend you don't put VL2 unit somewhere you can't get to. You will need access to the unit to pull the harness cable in-case you need to hard reboot. Glove box is the best place and it is what GROM recommends. Just follow my install guide it's pretty detailed.
abapper (10-06-21)
Quick Reply: GROM VL2 installed
