90K mile service vs normal Oil Change?
Question for everyone. I just hit 90K miles. It looks like below are the list of items do for 90K service. My question is...I'm not due for an oild change for 5k miles, I can't rotate tires (staggered), I replaced both air filters myself and key battery. Should I just wait and go in for a regular oil change since they inspect everything then anyway? That way I'm not left paying for "inspections" and things I don't need?
List of 90K Items:
Replace engine oil and oil filter (0W-20)
Rotate tires (Applies to models with the same size front and rear tires and wheels.)
Replace air conditioner filter
Replace brake fluid
Replace engine air filter
Replace smart key battery
Measure brake pad thickness and rotor runout
Reset maintenance reminder light
Road test vehicle
Check installation of driver's floor mat
Inspect axle shaft boots
Inspect ball joints and dust covers
Inspect body
Inspect brake lines and hoses
Inspect drive belt(s)
Inspect engine coolant
Inspect exhaust pipes and mounting
Inspect fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses.
Inspect fuel tank cap gasket
Inspect rack and pinion steering assembly
Inspect rear differential oil
Inspect steering linkage and boots
Inspect transmission for signs of leakage
Visually inspect brake pads, calipers and rotors
List of 90K Items:
Replace brake fluid
Road test vehicle
Inspect body
List of 90K Items:
Replace brake fluid
Road test vehicle
Inspect body
List of 90K Items:
Replace brake fluid
Road test vehicle
Inspect body
List of 90K Items:
Replace brake fluid
Road test vehicle
Inspect body
List of 90K Items:
Replace brake fluid
Road test vehicle
Inspect body
It may be a good idea to let them do it a-la cart - so that you you can get the oil changes and inspections done.. and not have to pay for the filters and key-fob batteries.
Replacing brake fluid recommendations are all over the board. For example, for the Toyota Camry there is no recommendation for replacing the brake fluid, only instructions to inspect it periodically. It's not going to hurt to replace it, but it's most likely not needed.
I currently have 57k miles on my GS and am due for an oil change. The dealership quoted me over $1100 to do the 60k service (includes spark plugs). I plan on going in for a synthetic oil change, getting the multi point inspection and hearing what they recommend.
think your plan to get the oil change and included multi-point inspection is the best route (i'm sure they are gonna want a lot of $$$ for the 90k service). Hear what they say/recommend and then decide if you want to spend the $$$.
Oil change
I just hit 37k in my 16 is350 f sport on my way home from a long road trip when the yellow triangle can in saying maintenance required. I’m assuming that would be my oil change indicator? Just asking bc this is the first Lexus I’ve owned and have only had it for about a month.
Like you, I too plan to hold on to my '13 GS for some time - probably by the time I get rid of it, it will still have under 70k miles! However, as long as you feel comfortable with the price and the service of your dealer, that's what matters most.
jkeller (08-15-20)
