Oil filter housing question....
So I did my first at home oil change in my 2014 GS350 Fsport today and noticed something a little odd. I was expecting to find a filter housing with a drain plug and 3/8” square hole in the end. Instead I found one with no drain at all. The filter that came out was correct and fit like it should. This is a certified car and all of its service has been completed by the dealership until this one. Would the dealer have swapped this out?
Does anyone know if the filter housing with the drain port is still used on other engines?
I find the drain port is more trouble than it's worth. That plastic piece that comes with the new filter is a real pain to remove after you finish draining. It ends up taking longer and making a bigger mess than just removing the housing.
I have it but I don't use it.
I heard there are 3rd party drain tools that make it easier to use the drain port, but I never bothered.
NikonGuy
12-20-14 03:15 PM
